Thread: vectra c turbo petrol , tick over
    Regular Member davedave's Avatar
    Apr 2012
    manchester
    StatsVehicle Info
    Default vectra c turbo petrol , tick over
    hi ive noticed when my car is ticking over and parked up that its not ticking over smoothley.the needle on the rev counter is moving up and down very slightly and sometimes you can feel the engine in the car. also when im driving it and then coming to a stop a put my clutch in the needle sometimes drops , and on the odd accasion the car has cut out.any ideas, sorry for the big essay.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    StatsVehicle Info
    do you have a 2.0 turbo or a 2.8 turbo? If its the 2.0 then your engine is known as a Z20NET. Have a search and you will find a fair few having this issue at the moment, follow the advise in their threads and see how you get on..
    Bsically you have a process of elimination to follow before you want to go replace parts you may not need to. Start with a good service like new spark plugs and oil change, a new air filter, new fuel filter, run through some injector cleaner and put some decent high octane petrol in. Clean the MAF sensor, clean the MAP sensor, clean the EGT and/or lambdas. Clean out the throttle body. Check your spark plugs if you didn't change them, check your pipework for air leaks.
    Then take the car out and thrash it down the motorway keeping a sustained speed for a good distance to get it nice and hot, that should shift any crud and help clean the cat.
    try the pedal test to read off any fault codes (see here >>>> http://www.vectra-c.com/forum/showthread.php?t=81742 )
    Regular Member GoldenWonder's Avatar
    Durham
    StatsVehicle Info
    Its seems to be cropping up on a few turbos!
    I've done the air filter, fuel filter, plugs and cleaned my throttle. Made no difference to the idle speed. Next is the CTS and taking it into the high revs a few times.
    Apr 2012
    manchester
    StatsVehicle Info
    Default vectra c 2litre turbo petrol engine diagram
    hi has any one got a diagram of a vectra c sri 2litre turbo engine showing where most of the sensors are mine is the 07 plate as i could do with cleaning them
  1. Vectra c 57 plate 2.0 turbo petrol whats your thoughts
    By matrix1979 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2011, 22:27
  2. Vectra c 2.0 turbo petrol
    By vectraz20let in forum Engine & Drivetrain
    Last Post: 26th January 2011, 17:31
  3. Vectra C 2.0 l SXI petrol turbo
    By ade515 in forum Engine & Drivetrain
    Last Post: 29th July 2010, 15:09
  4. Replies: 6
    Last Post: 31st August 2008, 17:47
  5. Total Vauxhall photo request - 2.0 petrol turbo Vectra/Signum
    By Dougie_SRi in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2008, 21:39
vectra c 2 litre turbo service
vectra sri turbo tickover
vauxhall vectra c 2.0 turbo petrol cleaner
