Thread: 1.8 revs stuck after starting, EM on!
    Hull
    Post 1.8 revs stuck after starting, EM on!
    Hey all,
    A few weeks ago I had problems starting, it started but after a few seconds it stalled, it then took about 5 or 6 attempts to start again, seem to turn over ok but just wouldn't start, was fine after it started. Before hand the car was left for 2 or 3 nights in damp and wet weather.
    Today though, started fine, went about 1/2 mile to shop, came back out and the engine started but the revs kept going to idle speed, then the engine nearly stalled but the engine went back to idle, with the EM on and just kept this cycle until I turned it off. After another attempt the car started but this time the revs went up to about 2000 rpm and stuck there with EM on. On both times pressing the accelerator did nothing. Tried turning on ignition but not starting engine and EM still came on.
    After about 4 or 5 attempts at starting it started normally and has been fine since...
    So, anyone got any ideas? I'm lost. Can only think of the O2 sensor but there's that many these days... only other thing I can think that is relavent is that mpg seems rather poor atm...
    Its a 1.8 petrol 53 plate.
    Going to try and get the fault code read when I can find someone with a reader...
    Feb 2011
    Selby
    Don't need a fault code reader for a 1.8
    Just press brake and accelerator pedals and turn ignition on (don't start it). The codes will flash on the MIL.
    Do a search for the exact procedure if it doesn't work for you - I know it did work on my 53 1.8 Dual Fuel Elegance, but since spending a whole £10 on a USB to OBDII/EOBD interface I haven't needed to do the pedal method.
    Hull
    Found a post about using the pedal method for the fault codes and tried it earlier on, got the following codes...
    1525 - Air bypass valve system
    1526 - Air bypass system
    1550 - PSPS out of self test range
    Found on other posts that this could be a dirty throttle body issue (remember having a similar prob on a Calibra) so followed the guide on here and removed it earlier, cleaned it out by steaming the dirt out, fitted back in and seems ok. Will just have to wait and see if it solves the prob.
    Have added some before and after photos in the hope it will help others...
    Before...
    After...
    Hull
    So I've had a run out in the car this morning and things seem good.
    Used to have some hesitation when going from 1st to 2nd under hard(ish) acceleration, but now it just continues accelerating after changing.
    Now just gotta look at fuel consumption...
    Feb 2011
    Selby
    Excellent.
    You should be able to get 50mpg+ on a 1.8 if you try hard enough (never exceed 2000rpm except on dual carriageways, leave plenty of room from the car in front so you don't have to brake when they slow, don't use cruise control, keep the revs constant not the speed etc). My normal driving style gets more like 41mpg though.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Was the top side as bad as the bottom side? Might take the intake pipe off for a look and see how bad mine looks.
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    don't forget to clean out the breather pipe holes as well, these can be completely blocked..
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Hull
    The inside body part was the worst with only a bit coming through to the outside, but the valve was filthy on both sides and around its edge which i think combined with the filth on the body was making the valve stick.
    As soon as i took pipe off the top of it i could see the valve was filthy so just took the full thing out to clean.
  1. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  2. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  3. Intermitant Problems Starting - Revs limited to 2K
    By Beridor in forum Engine & Drivetrain
    Last Post: 6th July 2010, 16:30
  4. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
  5. Revs to 3k immediately after starting
    By Senator in forum Vectra C / Signum Troubleshooting
    Last Post: 15th May 2008, 17:06
