Thread: Vectra C Wagon Canīt open trunk
    Jan 2012
    Denmark
    Default Vectra C Wagon Canīt open trunk
    Hi There
    Yesterday, my Vectra c Wagon would not let me in the Trunk
    The switch was replased 1 month ago, so thats brand new. When i activate the switch nothing happens.
    I think that there is no power to the switch, can anyone inform me if there is a fuse for the lock/switch
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    There does not appear to be a fuse just for the tailgate .
    The tailgate mechanism is all part of the central locking system which is supplied via F20 7.5A in the rear fuse holder .
    When you press the switch can you hear the release mechanism motor operating if you cant then i would suspect the switch to be jammed again .
    They are very susceptible to road gunge so may just need a spray with wd40 although the newer switches should have the mod to prevent this .
    and still loving it
    Jan 2012
    Denmark
    When i press the switch ther is no sound from the motor, like there normal is, but the switch have that kind og switch sound "Click" and that sound is not there when it is broken. I am pretty sure its a power issue, or the cable that have fallen of the switch in the tailgate.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Hejsa
    Det er sikkert kontakten (altså den du trykker på) som er gået i udu .. har en liggende hvis det er..
    Men kan blive fikset hvis det er..
    Sorry and now in english..
    Its probaly the switch thats faulty, they also fails some times.. you can replace it simpel (ive got one lying around)
    But can be repaired
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
  1. Auto rear level control on vectra wagon
    By zafira in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2011, 16:22
  2. Vectra c wagon subwoofer box measures
    By O-Peli in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2011, 13:45
  3. Not Vectra but Suzuki Wagon R question
    By Boy Lard in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2008, 22:12
  4. Trunk delay
    By lucasss in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2008, 23:46
  5. Fitting 12v in back of my Vectra Wagon
    By Peabrain in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2008, 07:49
opel vectra how to open trunk
vectra c trunk
