Thread: Z22YH - swirl valves
    Jun 2006
    Kirkintilloch, Scotland
    Default Z22YH - swirl valves
    2004 direct estate with 70,000 mls on the clock
    Can you observe whilst the engine is running the operation of the swirl valves?
    About 4,000 miles ago I had error code "P1112 - Swirl Flap Stuck" and at last I am ready to carry out the field remedy and replace them with the modified type.
    However for these last 4,000 miles I have been running on Shell V-power believing (rightly or wrongly) that it might clean them out and indeed the error has now gone.
    But I wonder if it actually ok now or somehow broken in such a way that it is not recording a fault.
    So the question is can I check the operation of the swirl valves without taking thing apart?
    Thanks,
    Dave
    Full Member spennny's Avatar
    Blantyre
    I also got this fault and cleared it, i need to fire some carb cleaner down the intake to see if that helps, i cant help you with your issue but i am watching this thread
    Jun 2006
    bump
    May 2006
    scotland
    Cannot say for your particular engine but if the operation is the same as the 1.9 diesel then there are numerous related posts on this forum i.e. when engine is off, the swirl valves are open at the 10 o'clock position. When at idle, they are closed at approx the 2 o'clock position. May or may not be of any help. Sorry.
    Jun 2006
    Thanks Willie.
    Yes, I spent ages going through all the (unfortunately) diesel posts before posting.
    Dave
  1. How to reach the swirl valves Z22YH
    By danhariga in forum Engine & Drivetrain
    Last Post: 5th August 2012, 00:19
  2. Swirl Valves......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 5th July 2012, 19:16
  3. swirl valves
    By srimike in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2010, 19:52
  4. Swirl Valves
    By dhwigston in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 15:13
  5. Swirl Valves
    By dougiemc in forum Engine & Drivetrain
    Last Post: 9th June 2009, 17:37
z22yh swirl flaps
