Thread: Front Lights issues on 03 vectra 2.2 elegance
    London
    Default Front Lights issues on 03 vectra 2.2 elegance
    HI ALL NEED HELP ASAP,
    Had an issue with display on vectra c, which I left battery off for.a day then took off air vents and the clip was.loose.
    I then connected the battery and now I have a problem with various lights failing, the bulbs are fine but the message on the display says
    N/s turn indicator, n/s high beam, o/s fog light and o/s dipped beam.
    I checked all fuses twice in side of door,boot and bonnet, can't figure it out and don't wanna go to the stealers. Any help appreciated.
    Car has been problem free for 59,300k miles and is 53 reg relevance. Need to resolve asap.as I don't wanna get stopped at night by the bobbies.
    11 Post(s)
    Try disconnecting and reconnecting the battery again.
    You might have accidentally put a spike across the electrics last time you connected it back up.
    London
    Maybe me being stupid, but what do you mean ? Spike
    11 Post(s)
    Voltage spike - Wikipedia, the free encyclopedia
    Or in laymans terms you didn't make a clean connection when hooking the battery back up and upset the electronics of the car.
    London
    confused
    Hi big Dave
    Tried disconnecting battery nd then reconnecting same issue.
    London
    Any ideas anyone!??????
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    Clean up the contacts on the battery.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Maybe give this a try mate as the original poster had a similar issue to yours
    As per Mucklestones post HERE
    Sometimes if the bulb blows the module fails to turn it back on when it is replaced. With the ignition on but the lights switched off short the contacts for the bulb that will not light. Then replace the bulb and switch on the lights and Bingo! it works......
    Mine did the same thing before MOT last year and a friend showed me this trick.... Works like a charm...
    Might help????
    Good luck
    Damo
  1. Vectra interior front light module (with map lights)
    By parsco in forum Parts for sale
    Last Post: 12th July 2010, 08:48
  2. Elite/Elegance rear lights
    By The Gas Man in forum Parts for sale
    Last Post: 17th February 2008, 17:39
  3. Veccy C Elegance tail lights
    By Vectra_Power in forum Parts for sale
    Last Post: 14th July 2007, 00:51
  4. Standard Elegance tail lights
    Last Post: 19th December 2006, 21:00
  5. Vectra Front Fog Lights
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2005, 13:49
vectra c front light problem
