Results 1 to 10 of 18
Thread: 4,000rpm rev when idle, does not go past 4,000??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default 4,000rpm rev when idle, does not go past 4,000??
    At startup, starts first time spot on, I rev to check its ok but stops at 4000rpm but before it went to red zone.
    What can be the issue? Driving off stops at 4000 til 1 minute of driving it goes back to normal! Any ideas?
    How to kill an engine prematurely
    Keep revs out of the red at all times
    When the engine is cold us no more than 2/3 the available range; so if it is 4000rpm, limit yourself to about 2500rpm
    Equally, the diesel engine has a rev limiter, so it may be being applied (not sure about this engine) until the engine has run a few cycles / warmed up (reached a specific temperature)
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    This made sense now relieved car is totally back to normal.
    Cleaning egr valve and boost sensor valve improved car performance and causes car not to go past 4,000 at cold start. Makes sense why now. Thanks mate :-)
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    More to the point why would you want car to go past 4000 rpm at idle
    Or anywhere near it for that matter?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    yea theirs no point your just an idiot that shouldn't have a car
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by dan danz View Post
    U idiot
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by Critch View Post
    Only checking, don't mean anything at all, ensuring care is ok is my main point
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Yeah but that's thing I don't get what youd be checking revving it up too that high on start up?
    Apart from guaranteeing you kill your engine.
    Quote Originally Posted by Humourbash View Post
    Only checking
    Checking what?
    I've run my engine up to 4000rpm on idle a few times, but it is simply the same as the MoT test where the revs are raised and released instantly
    That is really the only time you should be doing
    Also note that during the MoT test the engine has to be at "normal operating temperature"
    This has delayed the MoT on my car each time, as the tester had to wait near on 20 minutes for the needle to start moving!
    On my last visit I suggested he take the car for a short drive, but he advised he was not permitted to do so and if the car left their premises the test would be nul and void
    As above, sustaining more than 3000rpm on idle will just kill the engine
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    what eggzakly are you checking are you checking for
  1. A Blast from the Past!
    By VectraMat in forum Non Vectra C/Signum Album
    Last Post: 31st January 2013, 22:01
  2. Whirring noise at 4,000rpm
    Last Post: 9th April 2011, 15:41
  3. Blast from the past
    By Vectralicker in forum General Chat
    Last Post: 1st December 2010, 10:47
  4. idle idle? haunted car lol!!
    By 1smokinace in forum Engine & Drivetrain
    Last Post: 27th May 2009, 21:28
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
