Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: Yrs (yaw rate sensor)
    Full Member spennny's Avatar
    Blantyre
    Default Yrs (yaw rate sensor)
    So keep getting faults thrown up and it keeps saying the above, what is the sensor for, can i simply delete it, or does it do something
    Its a 2.2 Direct 06 plate
    Regular Member Mopar Man's Avatar
    herts
    Its to do with IDS system.
    Blantyre
    But i dont have IDS on my SRI i dont think
    Can i remove it ??
    scottish region
    He does not have ids setup on his
    Glasgow
    Probably controls the alarm tilt sensor function aswell.
    Apr 2012
    portsmouth
    Yaw rate sensors are used for cornering brake control (or whatever each manufacturer wants to call it)
    It detects when the car is about to spin in conjunction with the wheel speed sensors and can apply individual wheel brakes on the wheels to regain traction and help prevent a car spinning under extreme cornering events
    It would be very difficult to remove and delete from the system i would expect due to it being linked into so many different modules in the cars electronics, probably better just to fit a new one
    Blantyre
    Quote Originally Posted by trimble View Post
    And in OP-C** its set to Present, can i just set it to NOT PRESENT ??
    Where is it
    Jun 2011
    Herts
    present means the fault is present not the unit otherwise you'd have thouusands of parts showing up as present ;-)
    Apr 2012
    portsmouth
    I'm not sure where it is, I'm a Citroen/Peugeot trained engineer !, I just know what they do and where they are on cit/pugs
    You could try setting it to not present, I am used to lexia diagnostics, where it was more complex to set, but it sounds a lot easier on the software we arent allowed to mention
    Blantyre
    Quote Originally Posted by FLOB View Post
    Are you sure about that one ? i think you may be wrong
    When i look at the other things that my car does not have there showing NOT PRESENT (i.e Rain/Light Sensor NOT PRESENT
    Even when i deleted the codes the Yaw rate Sensor is shown as PRESENT
    So i have just deleted the codes, and looking up on some other forums it could be one of two things
    1. CIM - I know mine is goosed as the cruise control is knackered , and the steering angle sensor has to be calibrated , and this is connected to the YRS i think so could be that
    2. ABS plug/module as this fault only happened over the last week or so, i am guessing there could be some water ingression in or near the ABS plug, as its been ****ing down for the last week so i am going to clean this out................ What plug is it and whats the best way to clean
  1. No Can Bus Communication with Yaw Rate Sensor
    By lee632 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2011, 22:45
  2. Yaw rate sensor
    By lee632 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 23:24
  3. How Do You Rate These ?
    By Tam80 in forum Handling & Braking
    Last Post: 21st January 2011, 20:56
  4. New Tax rate
    By MLC in forum General Chat
    Last Post: 24th March 2006, 15:58
yaw rate sensor vectra c
yaw rate sensor opel vectra c
yaw rate sensor location
https:www.vectra-c.comforumshowthread.php163567-Yrs-(yaw-rate-sensor)page2
vectra c yaw rate sensor location
How to wire in a yaw sensoe on a vectra cposition yaw rate sensor opel vectra cvectra where is the yawvectra yaw sensorvauxhall vectra yaw sensorvauxhall vectra vxr yaw rate sensorwhere is the yaw sensor located on a vectra cyaw rate sensor vectra c kalibracja vauxhall zafira Yaw rate sensor foultopel corsa c yaw rate sensoropel yaw sensor locationopel vectra c abs sensoryaw senser location signum 2006
