Results 1 to 10 of 20
Thread: Adding a CID to a CDC40
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Default Adding a CID to a CDC40
    Firstly why did Vauxhall not make a CDC40 NAVI??
    Or a CD70 with DAB???
    Anyway I have a CDC40 with Mono screen.
    I am looking to update to a CID or Colour Screen.
    Most Colour screens on ebay seem to be paired with CD70's.
    Does it need Tech2 to divorce a CID from a CD70?
    It is the CID or the CD70 or both that need to be divorced??
    As I currently understand it, it is the CD70 that needs to be divorced/married to/from the screen, and tech2 is the only way to do this.
    But a CDC40 can be divorced/married to/from a screen with non approved sortware??
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    The colour screen needs divorcing from the cdc70 and then it can be married to your cdc40
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Sorry, not made my question clear.
    Is it the head unit OR the CID OR both that needs divorcing.
    Can I buy a CD70+CID which are married, not divorce the CID from the CD70, fit the CID to my car, marry it to my CDC40 and leave the CD70 wondering where it all went wrong???
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you use Vauxcom, then they are both divorced simultaneously from each other and the car.
    If you use Tech 2 / Tech 3 / TIS2Web, then they are divorced indevidually..
    Personally I would divorced them both to be on the safe side - and to do a proper job.
    I am not 100% convinced that a CD70 with the aux-in facility could NOT be made to run a DAB unit.
    It just happens that the CDC40 has the aux-in fitted as standard, and it is these same wires that are used to receive the audio in signal from the DAB box.
    As far as I am aware, nobody has successfully done this, but then a lot of the DAB and CD70 experiment stuff was done before anyone knew much about the need for the aux-in modification.
    Note also that if you have them, then the DAB box and UHP (Telephone Portal) will also need to be divorced and paired at the same time as the display and head-unit.
    Also - if DAB can be made to work, then it will only be selectable by drop down folder at the top of the display screen.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Quote Originally Posted by Robsey View Post
    I make tests with CD70 navi and DVD90 navi and not working with DAB unit , ONLY CDC40 Opera work !
    CristianTM.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Okay Cristian -
    Being the CD70 God that I know you are,
    If you cannot get it to work, then nobody could.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Thanks Robsey, you're certainly busy tonight.
    All these posts, it must be all us peeps having an extra day off and thinking about all the mods we would like to do.
    Cristian, thanks for the info. I am only thinking about adding a colour screen at the moment. But maybe Vauxhall/opel could have made disk 6 on the CDC40 changer a sat nav disk.
    Quote Originally Posted by TonyP2020 View Post
    See the DVD100 Navi, have 6CD changer inside and a navigation DVD Made by Delphi-Grundig (that's a problem!) ,..but exist
    CristianTM.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    No worries, they keep me out of trouble...
    besides I have a load more queries to answer on another two forums
    The problem with the DVD100, is that I don't think we have any in the UK... Highest spec I've ever seen is the CD70.
    If we do have them in the UK, then they are rarer than rocking horse gonads. And definately none for sale anywhere.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    What have you started........
    http://www.ebay.co.uk/itm/VAUXHALL-A...-/261017668933
  1. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  2. Adding Aux
    By Ginge7289 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2011, 10:52
  3. Adding aux in to cdc40
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2009, 13:32
  4. Adding DAB
    By Blue Thunder in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2008, 21:57
  5. Adding Sub and Amp
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2006, 00:34
