Results 1 to 10 of 11
Thread: Cdti swirl flaps
    Apr 2011
    Las Vegas
    Default Cdti swirl flaps
    Hi all, just after some info about these stupid things. Gave the engine a quick clean and got some crud out of where the flaps are. The bar is in place and seems fine but couldn't see the bit that connects underneath due to so much stuff in the way . Now, got the wife to rev the car up after I had finished and the flaps don't move? Should they move with revs?
    May 2006
    scotland
    Rob, they should move as follows. With the engine switched off, they all should be in the 10 o clock position. Once you start the car and leav it at idle, they all should be approx at the 2 o clock position. If they follow this, it is probably safe to assume they are operating.
    Apr 2011
    Las Vegas
    Cheers for that mate, they do move a little when the car is turned on. So I guess that's a good thing :
    gwent
    Did have the same problem has I had fault code did some tests swirl bar was still on plus I brought a new inlet manifold. Did a full service on the weekend and put some forte diesel treatment in and the swirl flaps seem to be moving more now than before. So see how it goes if I get anymore problems with it I fit the new manifold
    May 2006
    scotland
    I sprayed nylon/rubber lubricant onto the swirl pots to keep them nice and free. This I did for many years. Eventually the connecting rod fell off as all the ones of my vintage eventually do. I then cleaned all the pots and glued 1, 2 & 4 in the open (10 o clock) position (leaving pot 3 to turn as per motor control). Car runs just fine, still returns 50+ MPG.
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    what glue did u use ?
    May 2006
    scotland
    Loctite runny superglue.
    Jul 2011
    wigan
    will this be ok for the heat and will it last , cheers
    May 2006
    scotland
    Time will tell. What I will say however, I used to loctite elements of two stroke model aeroplane engines and these joints lasted the test of time and they never smoked or caused fires. If you ever feel the temperature of one of these engines after a 10 minute run, they are burning hot and I mean burning.
    Even if the swirl valves do eventually start to loosen, I will just glue them again. It is a 5 minute job really.
    May 2006
    scotland
    And, I do not appear to be loosing turbo boost either. I analysed the turbo boost data from a live run yesterday and it peaked at 1.71 bar @ 1900 RPM. From what I can gather, a healthy boost number.
  1. cdti 120 swirl flaps
    By jymercer in forum Engine & Drivetrain
    Last Post: 12th August 2012, 00:12
  2. Vectra c 1.9 CDTI 150 Swirl flaps refurbishment?.
    By felixx in forum Engine & Drivetrain
    Last Post: 31st July 2012, 15:24
  3. swirl flaps
    By justin32 in forum Engine & Drivetrain
    Last Post: 7th January 2012, 18:34
  4. Swirl valve flaps on a 150 cdti
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 19:37
  5. swirl flaps
    By DAVE.B in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2010, 18:59
