Results 1 to 10 of 26
Thread: Sump plug
    Sep 2009
    Glasgow
    Default Sump plug
    Went to do oil change today, guess what sump plug wont budge.... looks like i need to get a garage to slacken for me.
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    I had the same issue!
    Ended up buying a Pella sump drainer!
    http://www.ebay.co.uk/itm/Manual-Oil...item483d961eb9
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    Breaker bar works a treat... If not a ratchet with a metal bar on the handle. My old astra mk3 took 2 of us and a 4 foot pole.... Felt so satisfying! Jst thought we sheared it at first
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Breaker bar as above, Keep upwards weight on the socket to stop it slipping off as-well,
    Feb 2012
    Ipswich
    Oh yeh forgot to mention the above! if you cant get gud upward pressure us a mallet n lever it up on the socket.
    Sep 2009
    Glasgow
    gave up will try another day can't be bothered removing undertray again., i was trying to remove when engine warm should i slacken when cool
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    I can't stand it when garages to that... It doesn't have to be done up so tight you could lift the car by it.... Persistence really mate. Breaker bar works a treat but keep the torx square up to the hole so it doesn't slip, and you end up rounding the hole..
    I do it with the engine warm, as the oil is thiner, but I would have though it would be more difficult with a cold engine.
    Matt
    Sep 2009
    Glasgow
    it's not the torqe type mate its a bolt, pain in the arse, was the same when doing drop links had to get the grinder out.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Try to crack it off when the engine is hot, but don't unscrew until cool.
    gwent
    Had the same problem staturday took me 4 hours to get it off in the had to use a cold chisel l to get it of put my new quick release sump plug in so I don't get any more problems!
  1. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. Sump plug
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 22:47
  4. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
  5. Sump Plug Nut
    By si_hoss in forum Engine & Drivetrain
    Last Post: 22nd February 2010, 18:32
