Thread: tech 2
    Mar 2012
    gillingham
    Vehicle : vectra c 1.9 cdti 150 sri
    Mileage : 122k
    Default tech 2
    Ello any one have a tech 2 at all plz as iv put hids in my vectra c sri and they keep flashing so need them sorted plz and one help me in the south east plz
    Engine : 1.9 CDTi
    If you come anywhere near Portsmouth give me a shout.
    gwent
    What you mean flashing are they aftermarket ones as I fitted hids and did not need tech 2
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    he may want his xenons activating as this changes the way the power is delivered to the lights so to speak normally its pulsed but i think its different when the xenons are activated but he could put some cancellors on them too and it can be done via opcom as well as tech2 hth
    gaz
    VOTING UKIP IN AVELEY
    5 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    pm plasma ..he is often down swanley way now
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    81 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by soulman View Post
    Is he? thats my neck of the woods,
    i have told coolj about Dean and asking him to turn on xenons to stop them pulsing whilst ignition on etc
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by coolj View Post
    As iv put hids in my vectra c sri and they keep flashing
    I'm guessing that could be because they are NOT "canbus friendly" as I made the same mistake and bought some slimline hids (not thinking) for my fogs and they flicker all the time unless they are switched on
    However now that HIDS-DIRECT have revamped their website I am not sure which ones to buy to replace them (Previous being 50W H7 6k) specifically for Vauxhall (canbus friendly)
    If that is indeed the case and they are "Non-canbus friendly" then I believe even a Tech2 session won't able to sort it (not 100% sure though)
    Hopefully someone can confirm this,
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    U'll need something to go with the kit, think someone mentioned this, something like a resister, "fools the ecu that it's fine" I think, surely someone will help u out, I don't think the computer can help or remap the ecu might do the job, not entirely sure tho. Am looking into new headlights set the hid type.
    The resistor is volt control, I've set my lights and fooled the ecu thinking its xenon. As its slightly higher output than resistor is set for standard lights.
    Year : 55
    Mileage : 92,000
    From what I understand, all the resister does (cancellor) is eliminate the "Bulb Failure" message that flashes up on the Radio display. Again can't quite remember.
    I did install the cancellors (resistor thingy) on my fogs but they still flicker when they are switched off.
    Dipped lights are fine no flickering what so ever (Canbus friendly HIDs+cancellors)
    Already replaced:-
    Alternator,
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Ahh, found it, canbus ballast. U need that to work with canbus type system or a bypass. Look it up :-)
  1. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  2. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  3. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  4. Tech 2
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 16:54
  5. Tech 2
    By cooky516 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 11:36
