Thread: Need help with my Mums Corsa please
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Need help with my Mums Corsa please
    Hi all
    My mum in her seventies now needs some expert help and I told her I know just the forum who can help. Yes im laying on thick arn't I.
    Basicly last year september time she has lots of water pooling in the drivers side footwell.
    Car is a 1.2 2001 Corsa two door.
    She took it to garage who found the fault to be water coming through the seals around the brake servo. They charge here 342 quid to remove and refit and seal the brake servo.
    Today I looked at it and water is pooling in the driver side footwell again.
    Passenger side is completely dry and the rear drivers ise is dry too.
    I checked both drain holes in the engine bay and they are clear.
    I pulled back the carpet to find that right at the top of the footwell is slightly damp and gets worse the further back from the bulk head I go.
    Im now pushing the carpet down on the drivers side and water is pooling up quite bad.
    The sealant used around the servo seems to be very thin. Im no mechanic but this doesn't look like it can protect to much.
    Is there anything else I should look for?
    I must admit I can't see any other signs of water coming in from the front apart from what I have decribed above.
    My next job is to go down to the garage with my mums car and ask them about it.
    What do you thinks lads and ladies. Have I missed anything ?
    Thanks in advance
    Mar 2012
    The Midlands
    What's the heating like? And the coolant level? - If the coolant level is low then refill it - run the car & check for water.
    My mrs's had the same symptoms but no where near as bad - would leak overnight when the car was turned off - turned out to be the heater matrix was weeping/cracked.
    Not too hard to remove - remove the triangular side trim on the driver's side under the centre console, then the cover to the housing & the two circular clips & slide the matrix out.
    Then stick a hose pipe in one end & check for any leaks.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by the1theycallthe1 View Post
    Thank very much for that. Very imformative.
    I will certainly check for what you said tomorrow morning when im back round mums to do some odd jobs she has outstanding.
    EDIT : Just to say have not checked coolant level or heater yet but will do tomorrow morning.
    Mar 2012
    The Midlands
    Good stuff - give me a shout if you need anything else
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : BMW
    Trim : SE
    Engine : 320D
    Check the windscreen as well, as i once had a motor into the garage seven times with a leak problem, i got so mad, i dropped the dashboard myself and found it was leaking from the windscreen. (It never had a replacement windscreen either)
    Not saying its the problem you got, but they must of put a couple of tubes of mastic around the engine compartment.
    Maybe worth a good look
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by phil67 View Post
    Thanks for that. It didn't even occur to me it could be there will check tomorrow.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Guy across the road had the same problem,googled it for him and there is loads of info from other forums on this problem very informative and loads of different causes,it may help you
    Regular Member R-man's Avatar
    Beds
    Same on my wife's corsa. It's friggin terrible, especially in the recent weather.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Cheers lads. I was going to google it but I thought I would ask here first as you lot are a wealth of knowledge.
    Will post up what I find tomorrow, watering can at hand
    Jun 2011
    Vehicle : vectra
    Year : .....
    JUst put in water in drivers footwell and everything that comes up is to do with corsa's it must be a right problem with them, and you won't need a watering can tomorrow it's gonna chuck it down,AGAIN !! good luck
  1. Mums Car Juddering Under Load 1.8 SRI (Z18XER)
    By toaffer in forum Engine & Drivetrain
    Last Post: 22nd March 2013, 07:56
  2. mums net
    By markj23 in forum The 'Off Topic' room
    Last Post: 8th May 2011, 22:51
