Thread: HELP door open display in dash
    Regular Member lee's Avatar
    northwest
    Default HELP door open display in dash
    the door open display in the dash is showing that the drivers door is open when it is not .
    because the light is on i cant lock the car with remote or with the key it locks then opens straight away
    any help would be welcome
    thanks
    lee
    Regular Member cameraman's Avatar
    Leicester
    Sounds like the switch on the drivers door, I think the car will lock if any other door is open, don't know exactly where the switch is though
    northwest
    thanks cameraman but with the other door/doors open it wont lock it just does the same thing
    anyone know where the door switch/sensor is
    thanks
    lee
    11 Post(s)
    Quote Originally Posted by lee View Post
    That's probably because the system thinks the drivers door is still open. I can lock my car up with any door (or hatch and bonnet) left open apart from the drivers door.
    No idea where the sensor is; at a guess inside the door itself, somewhere near the door stay bar?? Be careful not to tear the plastic membrane behind the door card though when you take a look as I believe the side air bags rely on a sealed membrane to work properly.
    [Ex]Admin Duncan's Avatar
    I think it's within the door catch bit, the door stay/catch plate as Dave said.
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    I've had this on and off recently,Vaux say there is no switch and it's all part of the door catch assembely - i can cure mine by undoing the door multi-plug and re-fitting
    Mine only seems to do it when i use the dead lock so i can live without it
    northwest
    thanks for your help lads
    the sensor is part of the door catch and its all 1 unit inside the door so its a new complete lock that i will have to get
    will let you know how i get on
    cheers
    lee
    Now in Girvan Scotland
    Lee, Just Cured Mine, Blasted The Door Control Switches With A Light Wd40 Type Cleaner After It Got Drenched In The Last Deluge Of Rain When I Was Gettinginto / Out Of The Car. It Is Impossible To Avoid It Getting Wet, Anyhow You Need To Spray The Switches Covering The Whole Lot And Then Keep Pressing The Switches On/off To Get The "oil" In To Release The Damp, I Also Sprayed The Wiring Connections Near The Door Hinges And Where The Steel Bar Connection Goes Into The Door Internals Where I Presume The Door Open Switch Is Located, I Then Left This Overnight, Came To Open Up This Morning And It Worked First Time, Every Time, Then Gave It All Another Coating (also Down Into The Door Pins Just In Case).
    Good Luck.
    Melbourne, Australia
    I had a problem with the passenger door being detected as open. Holden replaced the door module under warranty to fix it.
    You may want to try various combinations of locking and unlocking the door while playing with the pin and the door handles. I (temporarily) cured my problem this way.
    northwest
    thanks for all the help
    the moduel in the door was beyond repair so i got a new 1 and everything is now fine
    cheers
    lee
  1. Replies: 32
    Last Post: 2nd January 2013, 02:18
  2. Light on Dash, Advising Boot Open
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 20:45
  3. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  4. Door shows as open on dash
    By colashbury in forum Vectra C / Signum Troubleshooting
    Last Post: 8th June 2010, 20:37
  5. Driver side door shut but showing open on display
    By eclipse in forum Bodywork & Interior
    Last Post: 13th August 2008, 11:14
