Thread: Can someone tell me what this is?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default Can someone tell me what this is?
    2007 1.9 CDTI 120
    Can anyone tell me what the part circled is? Looks really corroded. Its at the front of the engine, just under the cover.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Looks like the return for the A/C but I could be wrong.
    Do you live near the sea? That may account for the corrosion. You should see under my bonnet.
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    its part of the water cooling system thats the bleed off valve on it
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Get some jenolite or similaranti-rust treatment stuff & catch it now before it rots through, by the way its a water pipe & the plastic cap/bung looking bit is for bleeding the coolant system.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Quote Originally Posted by the-wizard View Post
    I'll give that a go! Thanks ppl
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    As said it's a coolant pipe, take all of the loose rust off, coat in jenolite or similar and then coat with a couple of coats of hammerite.
    Must be something they changed on the facelift as mine is alloy
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by ftm100 View Post
    Yeah along with the top strut mounts. Mine are needing done.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Anyone know the part number for this? I think its called the "Pipe, Water Pump and Thermostat Housing Feed" I need it for a 2007 120.
    Jun 2009
    birmingham uk
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mileage : 106000
    Found two part numbers for this assuming sorted by engine number range, to E 5691260 is 93189081 from E 5691261 is 93194989 Hope this helps.
https:www.vectra-c.comforumshowthread.php163499-Can-someone-tell-me-what-this-is
vectra 93194989
