Thread: 1.9CDTI 120 - Rattle on idle (NOT a DMF problem!)
    Wales
    Default 1.9CDTI 120 - Rattle on idle (NOT a DMF problem!)
    All,
    I have a slight rattle coming from the engine bay on idle anyone ever had this? Symptoms are..
    • Only appears when warm
    • Pressing/releasing clutch makes no difference
    • Slightest blip of the throttle and it goes away
    It sounds like something is loose, but everything seems sound enough. Its very frustrating as the noise is much less noticeable under the bonnet! FWIW, been like this at least since xmas..
    Any takers?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Valve tappets or lifters? But I think you'd hear that from the engine bay.
    Whats the mileage?
    Wales
    Quote Originally Posted by Chunklamb View Post
    Whats the mileage?
    I did the valve clearances approx 18 months ago. So I doubt if its that, but worth a check especially seeing as it only happens when warm (N.B the 120 does not have hydralic lifters, unlike the 150)
    Sounds distincly like a noise coming form outside the engine, not inside it, if you know what I mean.
    50k miles on the clock.
    Regular Member danny567890's Avatar
    Aug 2012
    newport
    Vehicle : vectra c
    Trim : sri
    Engine : z19dt
    Mileage : 115k
    Sorry to lift an old thread but mine does this too. Had the cambelt, tensioner and water pump done last year. Had the aux belt, alternator and pulley replaced last week and she's still making a rattle on idle. Like you if I touch the throttle she goes quiet. So I'm thinking crank pulley. Did you manage to get yours fixed or can anybody else she'd any light on this? The sound does sound like it's an external noise too not a tappety noise more of a knock
    Wales
    turned out to be the flexi-pipe in the end. Noticed it was blowing very slightly, replaced it an cured the rattle at the same time!
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    I had similar noises a while back:
    http://www.vectra-c.com/forum/showth...around-2500rpm
    This may help.
  1. 1.9cdti 150bhp 55 plate vectra idle speed problem
    By Whiteknight841 in forum Engine & Drivetrain
    Last Post: 21st January 2015, 07:55
  2. Intermittent rattle on idle???????????????
    By will-crowe in forum Engine & Drivetrain
    Last Post: 13th December 2012, 18:05
  3. 2.0T rattle at idle
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 12:01
  4. Rattle on idle, dreaded DMF
    By Bjornatron in forum Engine & Drivetrain
    Last Post: 1st March 2012, 11:47
  5. Rattle clunking noise when revs drop to idle
    By pugs,signum in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd October 2009, 08:08
rattling coming from engine in vectra 1.9
zafira 1.9cdti tickover rattle
zafira 1.9cdti doesnt sit stedy on idle
2008 vectra 1.9 cdti idle rattling engine
zafira cdti dmf rattling
Vectra cdti rattling on idle
dmf rattle idle
zafira rattle at idle
vauxhall zafira rattle but not dmf
zafira rattles when idling
zafira 1.9cdti алтернатор dmf
vectra cdti rattling when idling
vectra flexi knockrattle
dmf changed slight rattle when idling
