Thread: power steering problem?
    Regular Member bigbrox's Avatar
    rosyth fife
    Default power steering problem?
    today after filling up with petrol i started car and i had to do a u turn and put car on full steering lock when i did this i lost power steering and power steering fault came up on dash,so turned car off for a few seconds and restarted no fault on dash and power steering fine now,i was wondering where you check power steering fluid as couldnt find it and if there may be more of a problem than low fluid,many thanks.
    Mine did this a few days after I acquired it
    Reported it to dealership (so that it was logged for warranty purposes), but it never happened again
    I put it down to having the car on a ramp and uneven surface
    The power steering level sensor is known for being over sensitive, so if it doesn't happen again in the next few weeks there is no issue
    If you want to check the power steering level, then you may as well topup at the same time (as it is a nightmare to access)
    Therefore purchase a small bottle from your local dealership
    As you have a 3.2, you need to remove the offside bumper and pretty much detach it all the way along the front (and underside) as well
    Alternatively, remove the offside bumper and then remove the offside front lamp assembly
    You can then use a torch to check the level
    To topup use a small pipe, rather than try from the bottle itself
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    All I can find in owners handbook is, Consult a workshop. I have a feeling the reservoir is located behind the front drivers side wheel arch cover. No doubt someone will know for sure.
    Beaten to it.
    Forget that it is on offside.
    3.2 v6 Signum and loving it
    I'm finding it rather concerning that so many people are suddenly reporting this...
    Looks like the unit consumes from the max to the min in about 6 years
    Equally, the lifespan is about the same, which is quite typical for an electrical motor
    However if it is just the level then it should return back to life on restarting
    If it is the unit itself, then once it has switched off, that is the end of it and it needs replacing
    However a failed level sensor can also cause this, but that's a different issue and solution
    rosyth fife
    thanks for the replys guys,well driving around today shopping and reversed parked with full lock on a few times and still no problems so hopefully its ok time will tell i suppose.
    Netherlands
    It happened to me last year. After few NOK/OK's the power steering died completely and power steering pump needed to be replaced. Hope it is not the case with your car. Maybe you can consult the service, maybe is something small now and bigger future troubles can be easily avoided by small repair.
    Quote Originally Posted by taiko View Post
    The power steering pump is a non-service unit on the Vectra C
    Hence the warning message and lack of power
    Equally, when it fails that is the end of it
    It can be repaired, but you will be without it for about 10 working days; normal practice is to exchange for a refurbished unit
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Can be a sign your alternator is on the way out, loads of previous threads on here.
  1. Power steering problem
    By Danwells72 in forum Troubleshooting
    Last Post: 9th October 2012, 16:25
  2. On Going power steering problem
    By gazspeight in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:18
  3. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  4. Power Steering Problem
    By llaregub in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 11:35
  5. Power Steering problem
    By H11LGX in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2006, 01:19
