Thread: Kw coilovers possible question for spoons
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Kw coilovers possible question for spoons
    Well my next upgrade is suspension and I was going to get myself bilstein b12's but I have been considering these kw coilovers my question is what is the ride like and does having these fitted put your tracking and alignment all to **** and increase suspension components and tyres wear.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    personally i wouldnt touch coilovers fella paulmac on here also advised mr leave well alone too as he has them on his vxr and says that every time you make a adjustment to the coilovers you have to have the tracking reset etc
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    That has answered that question then look like its b12's im just fussy to how low i want it to sit
    Cheshire
    The eibach kit can have Eibach or H&R springs do not buy through europerformance!!! they sold me a B12 kit with the minimal drop eibachs and refused to change them to the lower rated springs which i needed for the GSI.(i needed the Eibach up to 1050kg they supplied me the 1135kg units!
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by paul667 View Post
    Thanks for the heads up bud have you got any pictures of your car on b12's and how is the ride
    Cheshire
    Quote Originally Posted by pipamish View Post
    B12 is the Bilstein 'kit' usually comprises of lowering springs, H&R or Eibach Pro. complete with B6 30% uprated shox or B8 short travel versions.
    http://www.vectra-c.com/forum/showthread.php?t=131776
    The front did not lower! i now need to buy the inorrect Eibachs for up to 1050kg instead of the 1135kg springs on the picture.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Id really want it a tad lower i think ill hold out and get the kw coilovers
    Cheshire
    The B12 kit really delivers on the road and track.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    i would like the top of the front arch to be about an half inch away from the tyre
    spoons
    Guest
    I personally think coilovers are a waste of money unless you...
    a) have a team of knowledgeable technicians to adjust the geometry setup for every ride out / or track day
    b) have an obsession with really low ride height, regardless of handling or comfort
    I have KW Variant 2 coilovers and I think they are great quality, give me a superb ride height & good options for the future.
    But they are high maintenance to get right for high speed use, corner weighting, geo setup, camber adjustments / alignment
    Mine are at the KW recommended settings and I really dont want to move them again.... so being adjustable doesn't really mean anything once you've set them up
    Now I've got the damping, camber, alignment, height sorted out, NO WAY am I moving them now
  1. Question for those who have coilovers
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2012, 22:27
  2. Vec c coilovers
    By SUBEK in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2012, 20:46
  3. Coilovers.
    By Hyperhart in forum Handling & Braking
    Last Post: 20th June 2010, 19:40
  4. Coilovers question....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 19:27
  5. Which coilovers?
    By Matt21385 in forum Handling & Braking
    Last Post: 3rd April 2006, 18:02
