Thread: Has anyone changed the maf on the z19dth?
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Has anyone changed the maf on the z19dth?
    To cure the flat spot/hesitation or any other power issues, ive got the z19dth in my saab and im at the point where its either a new inlet manifold or new maf to try and cure my flat spot/hesitation , ive got no eml to suggest anything and gona start saving but dont want to buy the one if its the other if you know what i mean, there doesnt seem to be alot of mention on here of people renewing maf's , so just looking for a bit of feed back off ppl who have been in the same situation. Cheers guys
    Engine : 1.9 CDTi
    Have you done the usual check for swirl flap operation and cleaning of the egr as they tend to cause flat spots.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by lee gsi View Post
    After having to refit the swirl bar back on before and after reading tony1977 thred i decided to take it off and bond 1,2 and 4 in the open poss but no real diff , ive cleaned egr the proper way and even tried blanking but again no real diff, ive also renewed boost controller, map , fuel and air filter, just done thermostat , cleaned maf , renewd all vac pipes, tested vac pump, cleaned throttle body and soldered joints even though they looked ok ,i do ideally need a new inlet manifold but im not 100% convinced its that causing it so im only left with renewing maf mabe
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    The biggest difference in smoothness has been by changing the thermostat, its odd though because if i accelerate using part throttle it seems alot better but if i try to accelerat using half throttle or more thats where i get the flat spot/hesitation and seems to be holding back some power all the way through the revs could that be a sign of the maf not doing its job correctly? I dont know what else would cause it
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    UPDATE: soaked my maf in isopropynol overnight and dried it out on a radiator in the house until it was completely dry and refitted and there is a difinate improvement not massive but defo better and smoother on pickup, where it felt a bit dead on half throttle or more thats where i feel the difference after cleaning it, shall be saving and getting a new 1 in due course
  1. Oil for z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 18th July 2011, 18:45
  2. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  3. z19dth
    Last Post: 22nd April 2011, 08:38
  4. Z19DTH - Which Oil?
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:22
  5. z19dth
    By taralko in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2006, 13:36
