Thread: Rear demister problem
    New Member shaun_richmond's Avatar
    Jul 2011
    gravesend
    Default Rear demister problem
    Hi hope someone could help me out rear demister hasent worked since had the car and I've read on here that you take the big fuse out in boot and put in one above so I did that and it works but next day battery was dead so changed fuse back and was fine
    Anyone had this problem or know anything???
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Do you have any 'check safeguard' messages?
    Jul 2011
    gravesend
    No haven't got the trip computer screen in middle but I have inSP come up when I start car up where mileage is but that's not been doing that long
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    If you have access to a multi-meter i'd check the heater circuit. The spade connector had fallen off one side of the heater element on my old vec. It was as simple as removing the boot cowling and popping it back on. Hopefully yours will be such an easy fix. Can you hear a relay clicking when you press the button?
    Jul 2011
    gravesend
    Yer it did click wen changed the fuse over. Where is the heater element?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    it's the actual lines on the back window. Remove the covers at either side, pull one of the spade connectors off (if one's not already off) and check for continuity.
    Jul 2011
    gravesend
    Oh yes I've done that and the elements do work but that was only wen the fuse was moved up and then when I turned engine off there is still feed going thru that fuse
  1. Rear demister lines knackered.
    By elle2801 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 13:12
  2. rear demister prob
    By wilson002 in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2011, 18:26
  3. radio going off when rear demister on?
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2011, 13:01
  4. rear demister not working
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2011, 22:44
  5. Rear Window Demister
    By ROB WOODHOUSE in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2009, 08:02
