Thread: wire for rear interior light
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    Thumbs up wire for rear interior light
    hi i am going to wire up my rear interior light jsut wanted to know if this wire would be ok 1MM THINWALL CABLE AUTOMOTIVE 16A 12V.
    thanks
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    1mm cable is a bit OTT, 0.25mm will do, not that much current flow.
    If it helps, The easiest connector for the rear light I found (and based on older posts here) is a 3.5 Floppy Disk Drive connector.
    Jan 2012
    wales
    cheers
    Jan 2012
    wales
    where would i get 0.25mm cable from tried ebay
    Jan 2012
    wales
    what about 16/0.20, 0.5mm2, 11.0A - cable OD 1.6mm
    or
    32/0.20, 1.0mm2, 16.5A - cable OD 2.0mm
    i know nothing about wires lol
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Hi, sorry for the rushed reply last night.
    I assume you have seen the 3 How2's about adding a rear light.
    1st, have you checked to see if the wiring loom (ribbon cable) already exists from the front light to the new rear light??
    If it does then it is much easier.
    If no loom then adding the wires is a pain, but do-able.
    Do you have access to a scrap computer power supply??
    If so you can use the 3.5inch power connector and leave the wires as long as possible. Any connector for a HDD can be left in place, to try and leave the wires long enough to reach the front.
    I have the necessary wiring in work and can send it to you if this will help.
    Jan 2012
    wales
    thanks
    i have an old pc in the attic will have a look .
    Jan 2012
    wales
    yeah had one in the attic
    trimmed it down with a craft knife fits perfect thanks.
    just need to get some wire now.
    Jul 2010
    Oldham, Lancs
    Do what I did and just push the wires onto the pins with a bit of tape to stop them shorting out.
  1. Can't take out rear interior light
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2012, 16:48
  2. Rear Air Vents/Reverse Light Wire
    By DeeBe in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2011, 14:15
  3. Interior light wire colours
    By Graeme F in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2009, 20:53
  4. Rear Interior Light
    By John3v36 in forum Bodywork & Interior
    Last Post: 12th September 2008, 08:34
  5. Rear interior light
    By simonali in forum Parts for sale
    Last Post: 23rd January 2006, 00:09
