Results 1 to 3 of 3
Thread: Blower issue
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Default Blower issue
    Got in the car today and my blower is blowing the same speed (fairly powerful -prob number 3 speed) on 1,2,3 and then full speed on 4.
    I did the resistor fix about 18 months ago and have a spare fuse to do again but it not the same symtoms as last time, when it only worked on number 4.
    Any ideas?
    The resistor pack has probably failed internally and shorting across the internal tracks
    The pattern versions are cheap and reliable enough from eBay UK, so try one of those and compare
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    I had a spare thermal fuse which i put on the resistor and it worked so ended up being a cheap fix
  1. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2015, 21:09
  2. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 20:47
  3. No hot air out of blower
    By dannycturbo in forum Troubleshooting
    Last Post: 28th January 2012, 10:33
  4. Heater/Blower Issue... Relay problem with PICS!
    By lew1984 in forum Troubleshooting
    Last Post: 13th August 2011, 18:24
  5. blower
    By bakery in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 15:18
