Thread: upgrading from cd30 to cd40
    May 2012
    Reading
    confused upgrading from cd30 to cd40
    hi all im looking to upgrade my cd30 to the cd40 with dab will the wiring be there ready for the upgrade or will i have to buy the loom as i no the dab has a small ecu type receiver box. if the looms not in the car already can someone point me in the right direction to buy the sections of loom (dealer???) any help appreciated cheers, daniel
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It depends if you have a half-canbus car or a full can-bus car.
    On the steering wheel, do you have 2 scrollers or 6 buttons???
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    im thinking of doing the same i have the scrollers on mine
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    If you have CD30, or scrollers, then you have full CANbus set up.
    If you have a DAB box, then you can make up your own little loom, but you would need the 18 pin connector (as found on the TID displays of half CAN Vectra's).
    If you do not have the additional DAB box, then it is more or less plug and play
    Just need to check the 32 pin display connector for the power wires..
    Some TID's have only 1 brown (earth wire on pin 1) and 1 red (battery live on pin 5)
    The GID (Graphic screen) will need 2 browns (pins 1 and 2) and 2 reds (pins 5 and 3).
    Other than this, you are good to go.
    Do remember about the DAB aerial if you are fitting a DAB box.. try a patch aerial for simplicity. Saves routing fresh aerial wires along the roof, and changing the aerial base to include the DAB aerial component.
  1. CD30 To CD40
    By Chris SRi in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2012, 22:06
  2. cd30 to cd40
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 16:09
  3. replace my CD30 with CD40?
    By domokun in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 01:51
  4. CD30 - CD40 Dab Help
    By johnny1983 in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2010, 00:38
