Results 1 to 10 of 19
Thread: weird electrical problem
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Default weird electrical problem
    driving down the road earlier today i lost all clock function's, speedo, rev counter, milage and all light's, clock and dash lights worked fine when i put side lights on, it was like this for the remainder of my journey so stopped the car and with the help of one of my friends we checked all fuses in all 3 electrical centre's and looked for any obvious faults, all fine and seem'd ok, after this check clocks then comes to life on ignition key turn to poss 2 on 3rd go at turning and have been on since, i am thinking poss cim unit fault, no code recorded when checked with reader
    then rear turn signal lamp fault appears on off side, check lamp, fine, check 2 more lamps both fine but still nothing, check for power etc with multi metre nothing there...
    called AA
    he came out checked everything i had, then brake light gone on near side, he again checks fuses, test's for voltage, he then decided to put a fuse in REC number f24 and all goes back to normal and i have brake light and off side indicator working fine....
    is it pure coincidence and car has had a brain fart or is there something lurking ????
    idea's & opinions appreciated
    Midlands Mod Shop - NFFC.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Possible early signs of a CIM failure?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Haynes says REC F24 is "Battery voltage" and rated 25A.
    2 things I would check.
    1 is the voltage across the battery both with and without the engine running, including when the engine is reving at say, 2K, or more.
    2 is check for a loose earth wire on or near the rear lights.
    I found a brown wire with a 5mm ring connector just hanging on one (of the 3) rear light bolts, ie, the wrong side of the nut.
    I had no problems with the car before i refitted the earth wire, but somebody on here not long ago did have weird problems and cured them by fitting the earth wire to the correct side of the nut.
    HTH's
    Trim : Get a
    Quote Originally Posted by TonyP2020 View Post
    HTH's
    AA guy checked everything electrical in the rear of the car, he also did various test's to battery and both rear light unit's seperatley, he was there for around an hour checking everything and we even stripped the boot carpet out to check earthing point's and check for cable damage, all were good as far as he was concerned, he then looked on his tablet and placed this fuse in F24, iirc there is another fuse that said ''battery voltage'' in the REC when i looked at the manual, so god only knows....
    there was no fuse in in F24 originaly btw
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Trim : Get a
    Quote Originally Posted by troutybrown View Post
    oop's, cheer's mate, forgot to say i had checked that and all seem'd to be ok, AA man said i knew more than him about where to check....
    missus has car atm so am waiting for a call if anything goes wrong...
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    possible C.I.M fault/failure as been said Rich
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Deffo CIM by the sounds of it mate
    Clean ABS plug as also said, as it can cause similar issues.
    Maybe try battery disconnect for an hour too
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Did he check out alternator?
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Yes, F11 also says "battery voltage". Could be a bad connection on F11, and F25 is a duplicate one in parrallel.
    But the ABS plug checking thread is an interesting one.
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. Weird Electrical Problems 2002 2.2 SRI Help!
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2012, 15:25
  3. Weird auto trans/ electrical issue???
    By matt180 in forum Engine & Drivetrain
    Last Post: 11th September 2011, 22:54
  4. Weird electrical fault
    By stampede in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 20:29
  5. electrical problem
    By gazman123 in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2008, 12:50
vectra c earth problems
