Results 1 to 10 of 14
Thread: Need help wiring a LED Switch I bought
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Need help wiring a LED Switch I bought
    Hi all
    Bougth this whilst in maplins today so I can turn on/off my rear blue light I installed see this thread.
    I thought it would be easy but it has four pins at the bottom. I expected three so Im confused as to how to wire this in.
    Any help would be much appreciated
    P.S The light I want to switch on / off is wired to the rear ciggie lighter.
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Normally just the 2 outside ones mate.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by BLACK KNIGHT View Post
    Thanks very much mate. I will go and give it ago now and see what happens.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Right im being a complete plonker tonight.
    Its not 4 pins its 5 doh!
    After getting it under a magnify glass I can now see the lettering for each connection.
    Does this make any sense to someone please.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Done a wee bit of googling a came up with this mate
    The contacts shown in your post indicate a dual section switch. The contact labeled C1 (Common) is normally closed to NC1 (Normally closed 1), until the button is activated, then C1 is connected to NO1 (Normally open 1). Then when released, it returns to NC1. The very same thing happens in section 2 at the same time. In*effect 2 separate switches activated simultaneously. If higher current capability is needed, short C1 and C2 together, NO1 and NO2 together,*finally, NC1 and NC2 together. This effectively parallels the contacts for more surface area (metal-metal) hence more current can be switched.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks for that mate.
    It sort of makes sense to me but I going to leave it until tomorrow. Im tierd and prone to make mistakes now lol.
    For the meantime im going to drill the 18mm hole next to the ciggie lighter on the rear plate and fit the switch. Thats the easy bit.
    Cheers again
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Heres a quick diagram,
    Attachment 54934
    Positive and negative are for led,
    C1 is for you input
    NO1 normally open connection
    NC1 normally closed
    Is it a latching switch or momentary?
    Connect 12v to c1 and your light postitive to NO1
    I would wire led to illumination circuit,
    Hope this helps.
    Aug 2009
    Trim : SRI
    Mileage : 50000
    It is not a dual pole switch (not enough pins) that one does not work that way.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by ScotsDragon View Post
    Attachment 54934
    C1 is for you input
    NC1 normally closed
    Hope this helps.
    Thats has made it so much clearer for me now. Thank you very much.
    Going to wire it up tomorrow now as I have switched all the kit off and I know I will only mess it up if I continue.
    Trial fitted the switch. The bezel will be painted black sapphire and a USB socket is going in (also blue led). Can't wait to get it finished.
    Thanks again for you help.
    Aug 2009
    Trim : SRI
    Mileage : 50000
    Just noticed a problem, that switch is momentary, the light will only be on when you hold the button.
    You need a latching switch like this one...
  1. t/c switch wiring
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2013, 12:16
  2. Clutch Switch wiring?
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 13:45
  3. Wiring up the TC switch
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2010, 20:07
  4. Ignition switch wiring please!
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 30th August 2008, 00:05
  5. Need help on wiring a Kill switch
    By bruceybonus in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 08:30
