Results 1 to 10 of 15
Thread: Really annoyed now, blue smoke upon me again!!!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Really annoyed now, blue smoke upon me again!!!
    After so long having new bits replaced, 6 weeks of no problems apart from battery light coming on 5 minutes of driving, light fault that now is solved. I thought the car was at long last fixed til white blue smoke bellowing now
    What is a known fix? To pinpoint actual issue! Tech2 shows no issues so not electrical related problem, egr valve is spot on. So what else???
    Hope someone who had the bluefish smoke can help what was done to fix it etc so I can cross out the area and narrow it down further.
    Feb 2012
    lincoln
    How many miles ur car done? Mines smokes bad on first start up goes any after cars wam been told its valve stem seals
    Sent from my GT-I9000 using Tapatalk
    South east
    Blue smoke upon start up is indeed most likely to be caused by worn valve stem seals; blue smoke all or most of the time implies a more expensive problem further down in the engine rather than just the cylinder head.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    What engine?
    South east
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Not startup, it's more when engine is at over 80•c it does that,
    1.9 150
    240,000 full service history
    Not turbo
    Oil level fine, no faults come up.
    Regular Member frankoacoustics's Avatar
    Sep 2011
    Southampton
    I'm having the same fault, but my engine has only done 46k so fingers crossed one of us finds it
    I am here: http://tapatalk.com/map.php?si1afn
    Sent from iPhone ... Sorry about the spelling
    wirral
    27 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    If turbo seals are defiantly ok, have compression test done wet & dry
    Possibly worn piston rings
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    The booster valves cleaned, edf valve cleaned and recleaned but only did it to ensure its working well.
    Hose from booster sensor is cracked, ordered new hoses to replace but duck tape to temp seal til then,
    Rpm when idle is at normal but when I put foot down, it stops at 4,000rpm was expecting it to go further, what does that mean? It might be the Curput! ???
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Will have a quick see if prisons rings are ok, turbo valves definitely ok as I removed broken one for new one, checked valves and seals before I finished up so I know they're good. Maybe lower intercooler hoses on both side need replacing, want to do that cos its prone to split cos of being at the weak point really. Anyone know of the size etc so I can go get red silicone to replace and correct size dive hose clips too.
  1. blue smoke
    By Swedge in forum Engine & Drivetrain
    Last Post: 28th October 2012, 13:09
  2. Blue Smoke
    By Monkgti in forum Engine & Drivetrain
    Last Post: 30th July 2012, 16:31
  3. blue smoke
    By King of Lead in forum Engine & Drivetrain
    Last Post: 11th March 2012, 23:32
  4. blue smoke
    By matt.d in forum Engine & Drivetrain
    Last Post: 26th June 2011, 11:34
  5. 2.2 blue smoke
    By pyper_honda in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 22:52
