What are the main signs of headgasket gone n what test can i.do at home to check i have a vectra 2002 2.0 dti thanks
Sent from my GT-I9000 using Tapatalk
Check ya oil matey. If its creamy then the head gasket may have failed. Either open the oil filler cap or pull out the dip stick.
Sent from my iPhone 4 using Tapatalk
Water in the oil turning the oil to a mayonnaise type goo
Oil in water Header tank
Sent from my iPhone using My thumb
Oil is fine mate but keeps want coolant thought might need gasket
You may have a coolant leak somewhere then. Is the radiator ok?
Thanks mate ill have look..any idea on price if it raditor ?
