Thread: Anti roll bar link, and front shocker
    Regular Member davedave's Avatar
    Apr 2012
    manchester
    Default Anti roll bar link, and front shocker
    Hi people
    any one got any advice on a easy way to put back the antirollbar link back into the front shocker on a vectra as i found this really difficult
    cheers
    South east
    Long time since I did mine, but put a jack under the hub assembly so you can move the hub up and down to match the height of the droplink.
    Apr 2012
    manchester
    Cheers for that , do you no what size the nut is on top of the shocker to release the spring its a vectra c 2007 , ive noticed there is also a torx nut any easy options here to undo it all:d
    Apr 2012
    manchester
    hi when putting a new spring on the shocker do you need to compress this as well while you tighten everything up
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Strut top nut is 21mm Iirc and yes you need to compress the spring otherwise u will have no head left also jack both sides or tue car up makes it Easyer to get the drip links back on
    Apr 2012
    manchester
    Default spring
    cheers, do you need to compress the spring that you are putting on the shocker
    Yeah , basically you need to compress the spring while
    It's bolted in the shock , then once it's compressed it's then safe to undo top strut nut and change the bearing
    Sent from my iPhone using My thumb
    Apr 2012
    manchester
    the top shocker bolt is 21mm but would you use a deep socket for this as you also need to hold the torx screw for the shocker as well so it dosent all move when you undo the shocker bolt which is best to use or will it undo without it all turning
    Apr 2012
    manchester
    but if you use a socket then you cant get anything on the torx not sure what to use
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Hold the shock arm with mold grips the silver bit don't squash it though
  1. Anti Roll Bar Link
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 2nd March 2012, 00:50
  2. Front Anti-Roll Bar New 25.2mm
    By paulhb in forum Parts for sale
    Last Post: 7th March 2010, 14:14
  3. *New* front anti roll bar 25.2mm
    By danBoy in forum Parts for sale
    Last Post: 10th February 2010, 22:44
  4. Vauxhall vectra c front anti roll bar stabiliser link
    By matrix1979 in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2009, 18:14
  5. Front anti roll bar
    By Tom Tom in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2009, 18:38
