Results 1 to 10 of 11
Thread: Rotten eggs?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default Rotten eggs?
    Having a few problems with my car, its a 2007 1.9 CDTI 120 engine.
    The car has suddenly started to smell like rotten eggs!
    Its just had an MOT and passed on emissions so hoping its not the Cat Convertor and the EGR valve was also replaced under warranty just a few days ago.
    If I leave it standing for more than 48 hours, its an absolute **** to start.
    Could this be a sign that the battery is almost dead?
    Does anyone know how to check an alternator or the life of a car battery?
    Also, slightly off subject, the fuse for the front windscreen washer pump keeps blowing. It lasts a few day then "pop" the rear works no issues.
    Any ideas? Thanks in advance!
    South east
    I'm reasonably sure they don't test emissions on a diesel during an MOT, so there's no guarantee your cat is working. Rotten egg smell is usually caused by unburnt fuel reaching the exhaust.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Only a smoke test is performed on diesels.
    You'll need a multimeter to check batt/ alt
    Looking for 12.6v from battery and then 14.4v across batt when running to show alt is ok.
    Washer fuse could have a short somewhere that shorts to ground every so often
    Jan 2012
    Milton keynes
    Mileage : 38100
    Thanks guys... Just checked the Battery, 12.5 and when running its at 14 volts.
    Its become a right ****** to start after I had the EGR valve replaced... The confusing thing is the poor starting after 24-48hrs idle.
    Starter motor??
    I've also just put a fuel additive/treatment trough the tank, just at 3/4 full now.
    Oct 2011
    Essex
    Rotten eggs can be a cell gone/going in the battery. The low level of acid boils itself and causes the "rotten eggs" gassing smell.
    If you can top the battery up, you might find its below the level of the plates. (You might see the metal fins poking through the water - only add ionised water, supermarkets sell it with the stuff for Iorns) If not it might go pop (like below) it does happen, Ive replaced quite a few plant batteries (in the distant past!) where this has happened:
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Leak off pipes maybe
    Oct 2011
    Essex
    Quote Originally Posted by Critch View Post
    Is the Vectra to sophisticated, to try starting with the old trick of removing the fuel filler cap, to cancel the vacuum effect?
    Jan 2012
    Milton keynes
    Mileage : 38100
    The what? lol
    This is my first derv car car so I dont know where to even start looking with this thing. Normally I'd look at spark plugs, fuel filter etc...
    Oct 2011
    Essex
    The fuel pipes that return the unrequired diesel back to the tank.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The vec has 1 washer pump, it has 2 pipes fitted & the elec polarity changes to send water to the front or back, so not sure why it blows the fuse.
  1. Sex and eggs
    By Big Dave in forum Comedy & Humour
    Last Post: 21st March 2012, 22:53
  2. Low-down-no-good-rotten-exhaust. Will this fit my car?
    By dlp in forum Engine & Drivetrain
    Last Post: 24th March 2011, 20:34
  3. Chicken and eggs
    By John35 in forum General Chat
    Last Post: 13th January 2008, 16:37
  4. Cooking Eggs
    By AJA in forum Comedy & Humour
    Last Post: 24th March 2007, 15:13
  5. rotten weather!
    By pogo in forum General Chat
    Last Post: 15th January 2007, 15:11
vectra 1.9 cdti rotten egg smell
