Thread: two noisy problems in one!
    Regular Member oldcommando's Avatar
    kent
    Default two noisy problems in one!
    hi fellas.
    just had my 04 2.2 dti auto mot'd (had to have a new ns coilspring).
    now, i have 2 problems, yes they was there before the mot.
    when i drive over a slightly uneven road a metalic rattling can be heard from somewhere underneath, i am led to believe its a loose heatsheild?
    and secondly, when i am approaching a stop at relatively low speeds and apply the brakes a 'click/very mild clonk' can be heard and felt under the brake pedal.
    maybe a pad retaining clip?
    i thank you lot in advance as i have always had an excellent response on here!
    cheers.
    o/c.
    Full Member witty's Avatar
    Jul 2011
    HALESOWEN
    Vehicle : VECTRA C.
    Trim : ELITE
    Engine : 2.0 DTI.
    Mileage : 106600
    Had heat shield come loose on mine and got some big washers and sorted that job. I have also got a mild clunk the same as yours. Just waiting for the chance to have a look. I believe it to be the pad retainer clip.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    Quote Originally Posted by oldcommando View Post
    hi fellas.
    cheers.
    o/c.
    have a read of my post this may help you
    see if the symptoms are the same
    they are all common on this site
    http://www.vectra-c.com/forum/showth...ghlight=mounts
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Mine makes a clunk from the passenger side only and has been doing it for the past couple of weeks, about a year ago I fitted all new discs and pads ( Mintex) and last week fitted uprated drop links thinking it was this that was at fault.
    The clunk only happens when braking going forwards and not in reverse, so I dont think its the pads moving as I have checked them and the look snug in the holder and the spring clip is in the correct place, it does not do it every time I brake but if I have turned a corner and the brake later it clunks again, I have checked the spring and its not broken and there is no noise when turning the steering from lock to lock, the only thing I could think it might be is the ball joint on the bottom control arm, could this be the fault, do they go after 70K
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    Quote Originally Posted by skidmark1 View Post
    check that the front spring are not snapped on the bottom first coil
  1. noisy cat
    By vectrabtcc in forum Engine & Drivetrain
    Last Post: 15th February 2012, 10:51
  2. Noisy Fan!
    By suresh.chohan in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2011, 20:30
  3. Noisy Top End
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 09:45
  4. noisy car
    By mac12 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2007, 14:08
  5. Noisy car help please
    By Higgins in forum Engine & Drivetrain
    Last Post: 28th February 2006, 22:27
