Thread: Heater is only working when moving??
    VIP-Member MCD's Avatar
    NE Manchester
    27 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default Heater is only working when moving??
    Odd one this... Only. Started this morning? Fans work fine, but only get heat when moving? Come to stand still and they start going cold again?
    Looked under bonnet.. No visible leaks... Water level fine, temp gauge on dash works fine... Any ideas guys? 2006 1.9 cdti Vec.
    Cheers for Any help!
    Mike
    Noobtune 220bhp / 270lb - (07) 2.0 turbo SRi XP1 NAV - SUNROOF/AFL/CD70/XP2'd
    NE Manchester
    27 Post(s)
    Engine : z20net
    Mileage : 80k
    Hmm.. Been tinkering all Morning, checked the red valve under dash as per other threads.. Nothing wrong there!
    Any ideas please? Really lost
    May 2006
    scotland
    I had simlar in a mondeo. It was the water pump that had lost its drive. It was not siezed but the impellors were not rotating with the cranshaft. It was only when the car was moving that g-force was causing the water to move around. When going up a hill, the heater would work as the water was finding its way into the heater matrix. When going downhill, it would cool down.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You should be able to see the return water going back into the header tank, But if it was a major water pump problem it would be overheating, could be an air lock for some strange reason.
    NE Manchester
    27 Post(s)
    Engine : z20net
    Mileage : 80k
    Thanks guys... Really odd as been out to cinema, good 10mile round trip, drove normal and no overheat?
    Heaters got hot.. And when turned up slightly smelly? Not burning though!? Then went cooler??
    Garage job me thinks? Beyond me??
    Mike
    Regular Member Mopar Man's Avatar
    herts
    Your heater matrex has gone. You will find when you rev the engine, not in gear, the heater will work as it has slight block. Sounds like its leaking as well. Is there a how to on here anybody?
    NE Manchester
    27 Post(s)
    Engine : z20net
    Mileage : 80k
    Hmm... Ok, makes sense.. Recon I could change that? Is it burried in dashboard?
    NE Manchester
    27 Post(s)
    Engine : z20net
    Mileage : 80k
    Well.. Today it started overheating.. So it's in the garage! Hoping it's the water pump? Makes sense, not lost any water atall, runs a dream.. But as it started climbing to 100 degrees today.. Time to limp it to garage (which took forever with plenty of stopping!) I await the verdict!
    Mike
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    Sounds like classic water pump failure symptoms, hopefully an easy fix! Maybe worth considering fitting a new timing belt if the pump has got to be replaced, saves the hassle of having to get the belt done in the future.
    May 2006
    scotland
    Yep, as I stated, it sounded like a classic symptom of when my water pump failed. Hope it is as easy as that for you. When that happened to me, I just kept driving as it was midnight in the middle of nowhere and the car was almost shot in any case. Engine was sizzling by the time I got home. Traded it in the week after.
  1. Heater Not Working
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2012, 09:22
  2. heater not working
    By Dan. in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2012, 09:02
  3. Heater not working
    By Shadrack in forum Engine & Drivetrain
    Last Post: 25th February 2012, 19:54
  4. Heater not working..HELP!!
    By princess09 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2010, 08:27
  5. Heater no Working, no hot air Help Please!
    By darkstar32 in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2009, 16:04
