Thread: Indirect lighting
    Jul 2011
    UK
    Year : 06
    Default Indirect lighting
    Ive just fitted a auto dim Mirror has the light under the mirror but how does it turn on it hasn't came on yet when I tested the mirror before fitting I coverd both sensors and it came on I've only connected the 12v power and earth to cigaret lighter any thoughts on this thanks
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Tried it with the car lights on? Might only work if it assumes you are driving at night, and covering both sensors wouldn't necessarily emulate that. Otherwise... no idea!
    Jul 2011
    UK
    Year : 06
    Not connected to lights out just a 12v feed covering both sensors made it come on all have alook later
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's activated by the sensor on the rear of the mirror, it works independantly of the the lights anyway
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Make sure you cover the sensors before you switch on the ignition if you're testing it. It only senses the light threshold at the moment the ignition is turned on not before or after. Or at least that's how it works when factory-fitted.
    Jun 2006
    St. Helens,Merseyside
    Quote Originally Posted by john_k_sri View Post
    it just takes a while to react to the low light level if its been powered for a while, like a time delay incase your under a bridge or carpark level
    11 Post(s)
    If that's the case, why does the light on mine come on approx 30 seconds after I've drove into the garage?
    Jul 2011
    UK
    Year : 06
    Got it working put black tape on sensor 5 seconds and was totally dim and light on bottom
  1. Indirect Night Lighting
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 11:57
  2. LED Lighting
    By Flaninacupboard in forum Styling
    Last Post: 9th February 2008, 17:40
  3. Indirect interior light in rear view mirror ?
    By simac in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2007, 15:09
  4. Faulty indirect night lighting
    By Duncan in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2006, 14:24
  5. Indirect night light
    By ziplex in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2006, 17:29
