Thread: 2.0 Turbo a bit 'flat'
    Regular Member GoldenWonder's Avatar
    Durham
    Default 2.0 Turbo a bit 'flat'
    Hmm this is a tricky one to describe. My 2.0 Turbo seems to feel a bit like its underperforming. I know 175bhp isn't exactly supercar power in a family car but it seems to be to be a bit sluggish compared to my older 120bhp diesel.
    Its the first turbo (petrol - I've had quote a few turbodiesels) car I've had so I'm not used to the performance but it doesn't feel to me a huge amount faster than my other previous 1.8 140bhp vec - especially the 0-40 or so speeds.Pulling away from junctions sometimes it feels as quick as my old 1.8. Once you're in 3rd it seems to pull well and feel a bit happier, but when you're cruising at 70 in 6th on the motorway and want to overtake it sometimes seems to take a while to pick up - obviously this is where diesels are performing their best.
    I've put a pipercross filter in, new plugs and fuel filter is going in this weekend. Its running fairly smoothly (apart from a wobbly idle speed and the hesitation when its cold). I've checked hoses for leaks and all seems ok and the car seems to averaging 32mpg which seems to be about right.
    Its difficult to put my finger on it - but I feel something is lacking! I don't have the money for a remap as yet but is there anything I can check to make sure its performing its best? I thought about some injector cleaner etc but I always thought they were a bit like snake oil!
    Or is it just the nature of the engine/gearing on this car?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    U tryed running super unleaded mate makes a huge difference well try 99ron fuel
    Durham
    Quote Originally Posted by paulvectrac View Post
    Hmm have only been using regular fuel. Might give the super a try next tankfull
    May 2011
    bispham, blackpool
    put it on a rolling road that way you can see if its under powered and you will have a graph so you can compare to others that have had it done
    finally drove the brother in laws 2.0t the other day and they dont feel under powered only managed 1st and 2nd due to speed humps but they feel quick
    they feel even quicker when your a passenger
    i would be checking the turbo or hoses etc
    it should pull good in all the gears
    Durham
    Ive checked the hoses and all seem ok. I can hear the turbo whistle at around 1800 to 2500 revs. Its just pulling away from lights i feel every supermini and white van is well away from me!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I think you'll find that the cars a bit slow to respond in 1st n 2nd tbh..at least mine is and I have a bsr remap. Mind you she then picks up her skirts pdq when(and ''if'') 3rds reached at any traffic light gp.
    I would recommend super unleaded at the least..and Shell's finest,despite the cost makes a difference.
    BTW the car should pull smoooooth n steady after that...plenty of low down stomp n still puts a BIG grin on my face after 4 years..
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    use tescos super unleaded ..and also put some injector cleaning fluid in your next top up .
    South east
    Quote Originally Posted by nikroc View Post
    The remaps accentuate the difference in power between 1st and 2nd gears, and the higher gears, they're designed to do that to protect the drivetrain. It shouldn't be so noticeable in a standard car though.
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Running BSR stage 3
    Ive always used Tesco 99 Momentum fuel.. Few months back i reverted to unleaded due to rising costs in the stuff.
    MISTAKE!! Slow as hell!!!! Took at least 4 tank fulls to get it back up to performance levels id had before
    Make the switch to fuel others suggested.. and that i use.. sure you will see a change. But.. don't expect it in one tank full.. stick with it a bit
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    I've always ran mine on Tesco momentum from day one and its certainly not a slow car, a good service and some decent petrol should sort it out, maby try driving another 2.0 turbo see if it feels the same as yours, feel free to come give mine a good kicking im only down the road lol
    Sent from my Samsung Galaxy S II
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Wheel refurb, flat or not flat B4 lacquer
    By Grumpy1954 in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2011, 20:11
  3. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  4. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
