Thread: Interior Lighting and Additional Plugs
    Regular Member johp778's Avatar
    Apr 2012
    Leeds, W Yorks
    Default Interior Lighting and Additional Plugs
    Hi All
    Does anyone know if plugs for interior rear light and illuminated sunvisors will be under the headlining on my Estate? Or is the only way to take it down and look?
    Does anyone also know where the fuse is for the front interior light (not in handbook) and if it's possible to connect some footwell lighting at the fuse box, rather than having to run it up A pillars to the front interior light??
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Plugs should be taped onto the headlining ready for use but better to pull it down just to be sure.
    Why not run the connection for the footwell lights from the ciggy lighter?
    Apr 2012
    Leeds, W Yorks
    Hi
    Just pulled some of the rear headlining down for a peek, but couldn't see anything, but could have been further towards the middle of the car.
    I want the footwell lights to come on when the interior light does, so connecting to cig lighter would require a switch. I'm not keen on pulling headlining down or soldering onto contacts on interior light, as I don't have a steady hand, but I am happy with crimping terminals etc, so was hoping to find a normal wire to cut and terminal up as proper connection.
    I have an idea of mounting courtesy lights in the centre console, rather than led strips under the dash, which I think is not a problem, but it's the wiring to the light that's the problem.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Quote Originally Posted by johp778 View Post
    Hi All
    Fuse is in the fuse box in the car passenger side end of dash,position 12, 15amp second row in from bulk head third fuse down does interior lights boot light and blowers,its stated in the book as battery overload protection
    Apr 2012
    Leeds, W Yorks
    Hi
    Thanks, well with that in mind and what i've read, the wiring on the Vec is more complicated than a simple live to light and earth, so I can't connect to light via the feed, as it looks like the interior light wiring is a ribbon style, boo hoo!! Guess I will have to take the interior light fitting out and solder or don't bother fitting them at all
    Jun 2011
    Vehicle : vectra
    Year : .....
    Hi
    http://www.vectra-c.com/forum/showthread.php?t=85073
    Try this mate really good and no soldering involved this is what i,m going to use when i do mine
    Apr 2012
    Leeds, W Yorks
    Thanks Patch22, I had read that post, wondered if the connection would be secure enough without soldering, but great instructions and I would really like to add the footwell lighting, think I will end up doing it
  1. Interior Lighting
    By insignia28 in forum Styling
    Last Post: 19th July 2011, 16:52
  2. interior lighting
    By jay w in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2010, 19:59
  3. Interior Lighting
    By lizard in forum Styling
    Last Post: 16th February 2010, 23:36
  4. Vec Interior Lighting
    By Steve CDTi in forum Quick Photo Album
    Last Post: 9th February 2007, 20:59
