Thread: What's this??
    Regular Member johp778's Avatar
    Apr 2012
    Leeds, W Yorks
    Default What's this??
    Hi All
    Having a look in my engine bay, I noticed something that looks like an old fluid bottle, at the back below what I believe is the fuel filter housing, does anyone know what it is and if it should be there??? I've never seen this in an engine before, so beginning to think it either shouldn't be there or maybe it's someones attempt to cover something up or protect it??
    I think i have attached 2 pictures
    Paul
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Thats the power steering reservoir.
    Apr 2012
    Leeds, W Yorks
    Hi
    Thanks for that, Oh, I was expecting the PSF Res to be a clear plastic cylinder, but I hadn't looked for it.
    Paul
    Regular Member coldo's Avatar
    Scotland
    There are two types... Think the 1.9's and the big engine ones have it burried in the wheel arch area and is a pig to get to... The 1.8's 2.0's etc have this bottle which is great to get at and top up if needed... (or change out the fluid)...
    Feb 2011
    Selby
    The PAS system on the Vectra C is a low maintenance, semi-sealed type, so the bottle's hidden away and doesn't have the usual yellow cap for things you should be checking on. Generally it doesn't need topping up for about 100,000 miles or more - unless you've got a fault of course.
    Apr 2012
    Leeds, W Yorks
    Quote Originally Posted by coldo View Post
    Mine is a 1.9CDTi?
    Apr 2012
    Leeds, W Yorks
    Has anyone got a picture of the 1.9CDTi with parts identification, like what you get in a Haynes manual or should I buy a Haynes?
    Scotland
    ahhhh... well in that case i am 100% wrong with the engines that have this lol...
    I had to top mine up recently (took about one and a half caps to fill it back up and that's in 90k miles...)
