Results 1 to 10 of 18
Thread: Feasibility of adding preout RCA's to CD70?
    Regular Member spark001uk's Avatar
    Feb 2012
    LONDON
    Default Feasibility of adding preout RCA's to CD70?
    Right, I'm looking into actually adding some preouts to the CD70, I know it can be done (I'm an electronics engineer by trade), it's just a matter of finding the input lines to the internal power amplifier section and bringing them out (via a few passive components) to a pair/pairs of RCA leads. I am determined to do this because I want to keep all the non-audio features of the system, and still get a good output on the audio side. The awful clipping from the head unit at high volumes is almost certainly coming from the power amp IC's, probably due to power supply constraints, so my aim is to bring out the signal before this point to then amplify externally.
    Anyone thought of trying this also? A circuit diagram would be a good starting point, but I'm not holding my breath on that one, already had a pretty good look around!
    Feb 2012
    LONDON
    OK well I've found a circuit diagram for a kenwood head unit with preouts, and it doesn't actually look that complex a job at all I don't think.
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    Let me know how you get on. Planning on looking into the CD30 to see if it can be done.
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Feb 2012
    LONDON
    Quote Originally Posted by baz2003uk View Post
    No, that's what I'm trying to avoid, as it will still contain distortion at high volume. What I am aiming to do is add a low level RCA output to the unit by dismantling it and picking up the correct signals from it internally. Basically the idea is to end up not using the unit's internal amplifier at all.
    Mar 2007
    swindon
    Quote Originally Posted by spark001uk View Post
    My Bad then
    sorry i cant help
    baz
    Feb 2012
    LONDON
    That's ok mate, thanks all the same for the input.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    When you do this, it will certainly be a popular mod. Whilst you're at it can you please make a device that stops LED's flashing with the bulb check pulse
    Feb 2012
    LONDON
    Does anyone know who makes the head unit by any chance? It may help me track down a circuit diagram / service manual.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Most are Siemens VDO units.
  1. Replies: 10
    Last Post: 3rd June 2012, 19:33
  2. Adding Aux
    By Ginge7289 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2011, 10:52
  3. Does the stock Vauxhall headunit have a preout??
    By nick_s in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2009, 08:07
  4. Adding DAB
    By Blue Thunder in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2008, 21:57
  5. Adding Sub and Amp
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2006, 00:34
https:www.vectra-c.comforumshowthread.php163311-Feasibility-of-adding-preout-RCA-s-to-CD70
rca w cd70 navi
can u put pre-out to cd70
