Results 1 to 10 of 16
Thread: Wierd Creeking noises when moving off!
    Regular Member Steve 100's Avatar
    Apr 2012
    Grimsby, Lincs
    Question Wierd Creeking noises when moving off!
    I have wierd creeking noises when I move off. I've had a look underneath and can't see anything untoward. Anyone else had this? Could it be dry bushes??
    Apr 2012
    Grimsby, Lincs
    Anyone? Can't believe no-one has not had this prob or similar!!
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Front or rear if front its likely the drop links and if its likely the rear sticky handbrake mechanism
    does it go away? does it happen when going over speed bumps slowly?
    Some more detail in the sysmptoms please
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    If it happens at low speed and only when moving off, it could well be the radiator mounts. Common problem.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    Quote Originally Posted by john_k_sri View Post
    what he said
    http://www.vectra-c.com/forum/showth...+mounts&page=2
    http://www.vectra-c.com/forum/showth...adiator+mounts
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    also try
    after going at this day after day, i have sprayed silcone lube over almost everything that could creak or squeak and finally think i have narrowed it down to worn out engine mounts, the front one in particular..
    I will leave it lubed up for now and hope it gets through the MOT this friday with it while i source some uprated powerflex ones if they exist, time for another call to my mate Nick at Neo Brothers i guess..
    try and get somebody to pull forward while you stand next to the car with the bonnet up and see you can locate that same, i had the wofe behind the wheel while i climbed up onto the front slam panel, i hung onto the back of the engine bay while on my knees while the wife pull forward a few times and the found the noise to be coming from the front mount
    Apr 2012
    Grimsby, Lincs
    Thanks for the replies guys! I have been spraying silicone lube like no tomorrow under neath! It is more when pulling away and does seem to be louder when going over speed bumps. Also seems to be worse when the weather is warmer/dryer!!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    it is the common problem with the Radiator Bushes.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Front lower engine mount. Take it off and lay it on its side, spray silicone lube spray around the circumference of the rubber bush and leave it for 10 mins ish so the lube creeps through. The bolt it back to the car and try it. Sorted mine. E18 socket and an 18mm spanner is all you need for this, oh and silicone lube spray of course.
    Let us know if it works for you as well.
    Apr 2012
    Grimsby, Lincs
    Quote Originally Posted by Caveman_nige View Post
    Thanks for that. I don't suppose you have a pic of the front lower mount?
  1. Replies: 15
    Last Post: 8th January 2013, 10:11
  2. rear end creeking
    By wobblywayne in forum Suspension, Wheels & Brakes
    Last Post: 25th March 2012, 14:42
  3. creeking drivers seat (driving me mad)
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2010, 13:16
  4. creeking
    By Signumbaby in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd March 2010, 23:16
  5. Bouncy Rear suspension and creeking
    By s0501291 in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2010, 11:03
