Results 1 to 10 of 23
Thread: Question about GID...
    Regular Member hadiislam's Avatar
    Apr 2011
    Newcastle upon Tyne
    Default Question about GID...
    Does the gid need to be told what size engine it is going to be calculating the data for? For example if it's came from a 3.2 GSI and is now fitted in a 1.8 SXI would the screen need to be told or does it just pull that data from the initial programming done?
    Thanksssss
    Regular Member coldo's Avatar
    Scotland
    As far as i know it needs to be set to pertol or to Diesel and that's about it.
    The "other" software used on here gives only two options for this but i belive Tech2 gives more options... Not sure why...
    Someone will be on shortly to confirm it for you bud...
    Apr 2011
    Newcastle upon Tyne
    Yeahhh I used the "other software" ad the only options I had was 007 and 008? Not sure what they mean but following the instructions I clicked the higher one... The only reason I ask is the GID when unplugged and put back I always goes back to 417 so not sure f it's programmed to a certain car which maximum miles out of the tank is 417 :s. lol but thanks for the reply dude. As always all replies are appreciated .
    Scotland
    007 is petrol is it not and 008 is Derv... I thnk...
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    There are loads of different settings in Tech2, but if you are using that non supported programme from Ebay then its basically just the 2 settings. The GID I fitted came from a 3.2 and it works just fine in my 1.8.
    Scotland
    That would be the "Other" software
    Apr 2011
    Newcastle upon Tyne
    Ohhh is it? Lol I selected 008 and mines a petrol... I was under the impression for some reason that 007 was non GID and 008 was with GID :/ lol or am I just chatting crap :s. And yeahhh the other software is the non supported one, did you use tech2 or the other one? Thankssss
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    There's a list of all the variant config code indexes that someone else posted up quite some time ago...
    http://www.vectra-c.com/forum/showpo...4&postcount=10
    Scotland
    The "other" one initialy and then had it checked by a friend with Tech2.
    This one does get more confusing however...
    I did a search and foudn this thread which sugested the 007 means no BC and the 008 means BC is present and nothing to do with the engine type...
    http://www.vectra-c.com/forum/showthread.php?t=122042
    Then there is this one...
    http://www.vectra-c.com/forum/showthread.php?t=125046
    It sugestes the code index is to do with the type of car you have (estate, signum, hatch, ls etc...) and the link from the page is all forgen but using translator and my random head i would say if you have an Estate then the 008 code is best and if you have a hatch then the 007 is best...
    I think...
    God this is confusing lol....
    Scotland
    Quote Originally Posted by Ian-Highlander View Post
    Yep.. that's the transaltion I was lookig at...
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
