Thread: Window switches
    Regular Member coldo's Avatar
    Scotland
    Default Window switches
    My new Vectra’s window switch is looking a tad scabby at present (mat back trim is flaking off it for some reason)… So I have been looking at new switches etc on ebay…
    This reminded me that I had a complete driver’s door switch spare in mint condition already…
    So my question is can I swap the standard passenger side three button switch out for a driver’s door switch module and will it all work (or some of it depending what wires are there in the loom?)
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The plug's not even right and even if you re-wired that, no it wouldn't work.
    Scotland
    Well that's killed that idea... lol...
    Now thinking that a small bit of carbon wrapping could be the answer... thepassenger side is the easy side to do but is the driverside...?
    I have had the switch out before but is it possible to get all the switches out of the cluster so I can wrap the remaining static buts (bit in the middle etc?)
    Or should I just Man up and spend £20.00 on ebay for a new switch?
    Thoughts...?
    you can get them apart but they are fiddly to do
    personally id just get a new one off ebay
    is it the one with or without rear electric windows
    Scotland
    Well, had a play about last night with the switches while having a few beers...
    Ends results are...
    The drivers door one is not perfict but it will do for the time being.. will come back to this in the near future to have a play about with it...
    Rugby
    Is it easy to get these switches out as the passanger window one in my vectra is very dodgy, only works sometimes
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Just a thin flat blade screwdriver to pop it out (be carefull tho). You can strip them down and claen them with electrical cleaner may fix the problem.
    Rugby
    Where are the catches behind the switch, top, bottom, left or right????
    Scotland
    Quote Originally Posted by Jax View Post
    Hi, it's dead easy to get the out... I used a thin flat knife (a normal screwdriver is to big IMO) incerted in at the top of the switch housing. This took the full switch and mounting out... then You can get the switch out from the inside.
    Go to the how to section as there is a guide for this and how to fix the issue with the intermitent function of your switch... a free and dead easy fix which I have done loads now!
  1. Window switches
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2012, 17:30
  2. Window switches
    By VeccyMike in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2012, 00:42
  3. window switches
    By elite lee in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2011, 11:38
  4. How do you disconnect the window switches.
    By garthmatthews in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 15:01
  5. Electric window switches
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2007, 00:02
