Thread: Number plate light module
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Default Number plate light module
    2007 Vectra estate
    I have no number plate lights working
    Got new actual number plate lights and bulbs
    New boot loom down to rear fuse box
    Still don't work!? Now been told of a module that controls them? Any ideas or part number/location of said thing?
    Thanks in advance
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    That module is the REC.......
    oh well.. I tried..
    Hhhmm that was the answer i didn't want lol.. thanks
    Engine : 2.2 Direct
    If you are lazy.. you just wire it to the normal rear lights.. job sorted ;-) maby not pretty but....
    oh well.. I tried..
    Dont think thats the best option with the canbus thing.. dont want to cause more issues
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    From what I can see, there is no fuse or relay.
    ------ it is a single black (live feed) wire direct from REC connector XR6A pin 10.
    (the live feed for each number plate bulb is linked).
    Each bulb has a link direct to ground...
    That is the entire circuit.
    If you are concerned about affecting the current from the tail light circuit, then run the feed via a relay.
    If you are not getting any fault symbols / messages on the dash already, then this will not make any difference.
  1. Number plate light
    By ronaldodg9 in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 05:18
  2. LED number plate light fault
    By SRIDAN in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2011, 21:58
  3. Tail light/number plate light wiring...
    By kyuudousha in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 12:34
  4. Signum number plate light
    Last Post: 3rd November 2010, 22:32
  5. Number Plate Light
    By kiwigolfer in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2009, 23:10
vectra number plate light not working
numberplate wiring vauxhall
which wire feeds no plate lights on a vectra c
