Results 1 to 10 of 13
Thread: Found another feature
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    Default Found another feature
    Whilst adjusting the temperature in my car today, i noticed that if you press the temperature control button, it allows you to adjust both drivers and passengers temperatures together. I would assume that this only works with Dual Climate Control systems.
    did anyone else know this?
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    isn't it good. Then to go back to dual individual temps, press the temp switch and they are then seperate again.
    Quote Originally Posted by Elite2.2DTi View Post
    Regular Member cameraman's Avatar
    Leicester
    No, most of us poor low life didn't get climate control , although at least the Design has a slightly better than standard system
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Quote Originally Posted by cameraman View Post
    I thought there were only 2 types of air system, climate and ordinary non- climate?
    So what does the Design have?
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Is there a Temp button on the ECC?
    Feb 2006
    Dorset
    the Design has semi climate , Looks like this ....
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    There are 3 types: airco, auto airco (or semi climat like Dennis said) and ECC. And yes ECC has 2 temp switches (that can be pushed in)
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by VectraV6CDTi View Post
    Yeah, I'm confused too!! On models with CC it does that. If the passenger side is set to a different temp than the drivers, pushing on the driver's temp dial brings the passenger side to the same as the drivers and you can then adjust them both at the same time with the one dial. If the passenger side pushed their dial then they have independent control back. And vice versa if the passenger is the first to push the dial.
    I though the only other option was the straight-forward AC? What's yours got then Neil?
    Edit: Just looking at the specs the Design lists 'Automatic air conditioning' which sounds somewhere in between the normal AC and CC?
    Oct 2006
    Wellingborough
    The auto AC will maintain a temperature, but adjustment of fan speed direction etc is manual rather than electronic.
    Feb 2006
    Dorset
    Fan speed is automatic all you have to do is point the air in the direction you want it , which is something i prefer to do , my old focus ghis , always decided i wanted a face full of wind which was annoying and would blast you with cold air in the morning , the vauxhall system is like the renaults it wont pump the fan into action untill the water in the matrix is hot enough , so you dont get chilled 1st thing in the morning ,
  1. best feature about your vectra
    Last Post: 10th November 2011, 14:08
  2. Magazine feature FTW!
    By Keith Fusco in forum The 'Off Topic' room
    Last Post: 5th March 2009, 10:43
  3. mag feature
    By POAH in forum West Scotland
    Last Post: 5th January 2007, 16:40
  4. New Feature Found
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2006, 17:11
  5. have you come across this feature?
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2006, 21:03
