Thread: Noise from left front wheel :-(
    Redcar
    Default Noise from left front wheel :-(
    Hello guys
    After driving back from shop yesterday a noise has started coming from left front wheel. It sounds like a clicking/ticking noise as if something was stuck in a tyre on bike. Ive looked at the breaks and the pads and discs are ok. Iam just wondering what it is and if safe to drive for now. Any advice would be great. :-) Thanks
    East Ayrshire
    Trim : SRI XP1
    Could be the cv joint, this will make a clicking when turning. Failing that it might be a wee stone stuck somewhere. Jack it up and turn it by hand at straight ahead, right and left lock
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I assume you have checked the tread for stones?
    Sometimes stones get caught up behind the plate behind the disk.
    As stevie16v says jack it up and turn the wheel and if its a stone you should be able to work out where the noise is coming from. you might have to remove the road wheel and lay on the ground below the brake disk and look up and you will see the plate which might need to bent out to release the stone if there is one
    Redcar
    Ive took wheel off and pushed the brake plate and seems to be not there now after a quick drive around. It seemed more noticable when weight was on that side when turning on roundabout ect. Hopefully its gone if not back to the drawing board :-D
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by rollercoaster63 View Post
    yes you are correct when stones have been caught behind the plate they do only seem to make a noise when turning mostly at low speed
    Jan 2012
    dorset
    Vehicle : vectra c 2.0t
    Trim : elegance/custom
    Engine : 2.0 turbo
    Mileage : 100, 000
    Red face yarp i have same problem
    Hey people I got the same problem but on front drivers side, only clicks at slower speeds turning left... my mate checked it and said inner right cv joint looks like its leaking but I will check for stones in disc as this problem only started after I put on my new mintex drilled n grooved discs on... hope you get your problems sorted. You lot are a great help with other ideas.. vectra c 2.0t
  1. Noise from F/O/S wheel when turning left
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 23:24
  2. rattle noise on left front wheel
    By mtqn in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2012, 19:50
  3. Strange noise from front left going downhill
    By thegoldenbullet in forum Vectra C / Signum Troubleshooting
    Last Post: 29th April 2012, 22:21
  4. noise front left
    By msqualo in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2011, 01:05
  5. O/S Front Wheel Noise
    By Aidi in forum Engine & Drivetrain
    Last Post: 15th February 2011, 20:24
vauxhall signum 2.0t noise front left
Vauxhall insignia noîse from frony wheel
noise from left front wheel on vectra-c
