Thread: Corsa 1.4 Help
    Barrow In Furness, Cumbria
    Default Corsa 1.4 Help
    I know its not a Vectra but hopefully someone can help: Having trouble with a Corsa 1.4 8V that won't start.It turns over fine but doesn't sound like its firing. I've had a plug out and rested it on the engine (still connected to HT lead) and I can't see it sparking when cranking it. (It was done outside in the dark.)The immobiliser seems to be ok, the EML flashes once briefly (as it should) when the ignition is turned on and OpCom confirms immobiliser signal is ok. My thoughts are the dispack is the first port of call. Its a 1998 1.4 8v. Sorry for the wall of text but my phone won't start a new paragraph. Thanks.
    Dec 2011
    Seaham
    Borrow a coilpack and try that!
    Could it be the coilpack? Unfortunately I don't know anyone with a Corsa!
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Clean crank sensor
    Regular Member PCMALT's Avatar
    Jun 2011
    Peterborough
    Vehicle : Signum V6 CDTI
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    Quote Originally Posted by Critch View Post
    Clean crank sensor
    was going to say the same check the cam and crank sensor op-com will tel you on live data if the ecu is receiving rpm signal
    Cheers. Do you know where it is?
    Jun 2011
    Peterborough
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    cam sensor is on inside or around the cam-belt cover at the top of the engine you will see a solid black wire running to it.
    the crank sensor is near the bottom pulley on most corsas or on the rear of the engine near the gear box depends on what engine code yours is
    Top marks to everyone who said crank sensor!
    Been out and cleaned it tonight and fired up straight away.
    I put the same post up on www.corsasport.co.uk (still a member from my Corsa days) and only got 1 reply saying that I should be able to see a spark!
    Thanks to everyone who replied.
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Top job another from barrow. Right across the water from me
    Jun 2011
    Peterborough
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    Quote Originally Posted by Chris SRi View Post
    No problem mate glad to help
  1. corsa vxr
    By ecotommy in forum The 'Off Topic' room
    Last Post: 22nd February 2011, 19:26
  2. Anyone know anything about Corsa 1.2`s?
    By PeterVV in forum General Chat
    Last Post: 30th January 2009, 21:53
  3. Corsa C Alloy And Corsa D Grille
    By andy.l in forum Parts for sale
    Last Post: 6th May 2007, 12:46
  4. Corsa VXR
    By Madgunner in forum General Chat
    Last Post: 16th March 2007, 00:56
