Results 1 to 10 of 13
Thread: Slight Oil weap - by the filter housing
    Middlesex
    StatsVehicle Info
    Default Slight Oil weap - by the filter housing
    So I have a VERY slight oil weap.. Not enough to drip on the floor - but its there and I know it!! lol..
    So - looks like its coming from what looks like a sensor that 'plugs' into the engine block thats next to the oil filter housing..
    Am I right in saying thats the oil presure switch?
    If so - how are they sealed? Screwed in I guess?? Maybe need a new one?
    Its a 150 CDTI (Z19 DTH), just wanted to make sure it is that before I get a new one.
    thanks
    A
    Middlesex
    StatsVehicle Info
    OK - found a pic.
    Where I think its leaking from is the left hand red square... So I dont think that is the Pressure switch is it - as I think the pressure switch is the right hand one?
    So - whats the left hand one?
    A
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    StatsVehicle Info
    am sure they are the level sensor
    got one at work from a zafira that was leaking but never come back for it
    you have to drop the sump as they go inside
    Middlesex
    StatsVehicle Info
    Quote Originally Posted by lutonmatt View Post
    Ah Ok - was looking on the online parts catalogue but couldnt work it out.
    As I say - its just wet really - but annoying
    So sump drop! grrr - thats prob not a 5 min thing on that engine is it...
    A
    Middlesex
    StatsVehicle Info
    So looking at this:
    http://www.opeloem.com/vauxhall/vect...el_sensor.html
    Its likely to be part 17 and part 18 holds to the sump hole that you can see.??
    Regular Member benny's Avatar
    Feb 2006
    dudley
    StatsVehicle Info
    Yep looks like oil level / temp / condition sensor ... Most likely level sensor
    Middlesex
    StatsVehicle Info
    Quote Originally Posted by benny View Post
    Thanks Mate
    And thats a sump off job..?
    Its really only just wet so not really a problem I guess...
    Regular Member tommy1976's Avatar
    Apr 2008
    somewhere
    StatsVehicle Info
    could be rubber o ring on filter housing leaking
    Middlesex
    StatsVehicle Info
    Quote Originally Posted by tommy1976 View Post
    Nah - chaned the oil / filter only the other week.. TBH I havent cleaned it up - so will do that and see...
    As I say its only wet so not worried at the mo and will see how it goes.
    Middlesex
    StatsVehicle Info
    OK - I know this has been worrying you all and you have all had sleepless nights over it :P
    Well - I am please to tell you all that after further inspection - its not leaking.. It was actually just resedue oil from when the oil filter was weaping before I changed it... Since I changed this and cleaned it all up - all is nice and dry.
    A
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. 3.0 d Oil filter housing
    By Faz2726 in forum Y & Z30DT Specific
    Last Post: 14th February 2013, 17:06
  3. help me please oil filter housing
    By kamazoo in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 22:03
  4. GSI Oil filter housing
    By sickboyjay in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 15:06
  5. oil filter housing
    By andymcniven in forum Engine & Drivetrain
    Last Post: 27th March 2007, 16:47
