Thread: Front suspension woes
    Full Member
    Jan 2008
    93 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : ....
    Year : .....
    Default Front suspension woes
    i have a 2008 sri
    i have just fiitted sachs supertrouring shocks all around the car.
    i have eibach 30mm springs on them.
    im getting a knocking/rumbling from both sides at the front end when going over rough roads/potholes etc.
    when i removed the wheels, i could lift the struts up and down with out issues - as if the shocks were knackered.
    i have fitted new drop links as well.
    the bottom arms/bushes/arb/ball joints etc look a if they dont have wear/play on them.
    all the bolts etc are all tight.
    could it be possible that the springs are no good for the shocks?
    i was actually considering refitting the original springs to see if it would help, but ive chucked the originals out.
    any help please coz im at my wits end with the noise/knocking
    thanks
    rab.....................
    just noticed ive selected the subject as vxr - it should be vectra
    Regular Member m20_swe's Avatar
    Oct 2006
    greenock
    No knocking with the old shocks rab?
    Edit shocks
    WGAF#5
    Amended to Vectra
    gwent
    Talking
    Did you tighten the strut piston rod nut right up as I had a knocking noise I nip back with my airgun and no noise
    Full Member
    Jan 2008
    93 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : ....
    Year : .....
    Quote Originally Posted by wayne10244 View Post
    when i put in the torx onto the piston without the nut being held, the piston seems to turn - but thats the strut nut being held......should this do this?
    Full Member
    Jan 2008
    93 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : ....
    Year : .....
    Quote Originally Posted by m20_swe View Post
    Edit shocks
    av no got the old shocks marty
    gwent
    The strut piston will turn that why there's a torx star insert for you to hold when you tighten the nut to stop the piston turning. That why I don't use the torch star I use a airgun to tighten it up as you can round them so you can't tight them.
  1. Rear suspension woes AGAIN!
    By Keif in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2012, 21:16
  2. Front suspension
    By RBH in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2012, 15:25
  3. Replies: 10
    Last Post: 1st June 2011, 14:43
  4. Front Suspension...
    By dankidd in forum Suspension, Wheels & Brakes
    Last Post: 30th October 2008, 01:04
  5. front right suspension....
    By hsmeets in forum Suspension, Wheels & Brakes
    Last Post: 15th November 2006, 22:40
