Results 1 to 10 of 16
Thread: Gsi urgent help please guys
    Apr 2012
    Milton keynes
    Default Gsi urgent help please guys
    Hi all
    After having the gsi for a whole week I have walked round the front of the car a couple when it's warm a smelt a bit of anti freeze
    So today I thought I would have a look at it!
    After I had a look round I noticed a bit of water on the front of the block, now I can see its running down where then head meets the block on the front right handside above the gearbox
    It looks like it is running out from the centre of the v so does this mean it's likely the oil cooler is leaking somewhere?
    Any help would be very gratefull
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    If it's coolant coming out of the head then it's going to be the head gasket leaking out rather than into the cylinders... I had it on my Golf VR6. Have you got white residue on the side of the block where the coolant has been cooking off but none on the head?
    Photos really would be the best way of anyone diagnosing this on here.
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Mileage : 82000
    d.p
    Apr 2012
    Milton keynes
    No signs of a head gasket problebm( I think)
    I am stripping it down now
    The water is coming out of between the cylinder heads and running lip where the head gasket is
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Mileage : 82000
    That seems a pretty big sign of a head gasket leak... unless I'm missing something mate? Your car doesn't have to feel lumpy or smoky for the head gasket to leak. It just means that coolant is escaping out of the side rather than into the cylinders.
    Apr 2012
    Milton keynes
    well i have it fully stripped out
    but i cant really tell from where its leaking so its like what you said either head gasket, oil cooler or water pump???????????????????
    anyone?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Is it bit worth skimming the head it's only about 20 quid new gaskets and put it back together you will need be stretch bolts
    Apr 2012
    Milton keynes
    sorry thermostat not water pump
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Its the oil cooler lid that will be leaking, be carefull when removing oil cooler nuts as they usually rip threads of then you will have to replace complete oil cooler
    Apr 2012
    Milton keynes
    Quote Originally Posted by alanv6 View Post
    thats what i'm hoping mate!
    i need a pressure tester so i test it
    have you had problems with this then?
  1. Urgent help
    By BBMadness in forum Engine & Drivetrain
    Last Post: 15th September 2012, 18:47
  2. Urgent help please guys
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 4th July 2011, 17:54
  3. Urgent help please!!!
    By j13hdb in forum The 'Off Topic' room
    Last Post: 27th May 2008, 23:00
  4. URGENT Help
    By DarrenLee in forum General Chat
    Last Post: 19th March 2008, 23:14
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
