Thread: rear apex lowewring springs 35mm
    Regular Member davedave's Avatar
    Apr 2012
    manchester
    Default rear apex lowewring springs 35mm
    hi people
    just put rear apex 35mm lowering springs on my vectra c. ive not really noticed any difference. found them easy to put on , and was wondering if there is a specific way the go on.the springs have some numbers on them so ive put the springs on so they are facing upright , so you can read them. do they take time to settle , as im doin the front
    cheers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    They can take up to 2 weeks to compress fully mate
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    also bear in mind as your car is an SRi it was already 15mm lower than standard so it will only drop a further 20mm maximum on those springs.
    Apr 2012
    manchester
    Default apex 35mm
    maybe i should of gone with 40mm
    West
    Stick a bit of weight in the boot till they settle
    Dec 2011
    Seaham
    Pop a womans hand bag in the boot, that will make it sit down on the springs........
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    just taken delivery of a set of apex -35mm today going on tonight as i managed to break an eibach spring.
    hopefuly mine should drop to the same level as it being an elite originaly had higher springs.
    and the guys are right will take a couple weeks before they settle down
  1. vectra c turbo just fitted apex 35mm springs
    By davedave in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2012, 19:43
  2. 35mm drop on Apex Springs
    By bobmcn in forum Handling & Braking
    Last Post: 29th April 2012, 21:19
  3. FK 35mm springs before and after
    By vekky c in forum Styling
    Last Post: 22nd February 2012, 08:42
  4. 35mm Apex Springs
    By Cossy in forum Handling & Braking
    Last Post: 16th January 2010, 13:07
