Results 1 to 10 of 18
Thread: cdti 150 turns but wont fire :(
    Jan 2010
    Scotland
    Default cdti 150 turns but wont fire :(
    wee problem with my 150
    been running fine all morning nipped to the shop parked up came back out 30 seconds later and the bleeding thing wont start.
    The car turns over but does not want to fire, it was running fine not 30 seconds previous to this and tbh i'm baffled
    a quick check shows the belt is turning and is intact so no panic yet.
    not a fuel issue as i filled up 2 days ago and still have 3/4 of a tank.
    checked fuel pump fuse and seems fine(swapped for another just to be sure
    disconnected the AFM as google suggested this can cause a non start, car wont start connected or not.
    any suggestions on what to try next Vec-C?
    dont have access to a code reader until later on tonight but it seems a strange one
    Regular Member poves's Avatar
    lancashire
    If you bounced up a kerb it could be fuel pump knock sensor.
    Not sure if the diesel models has one or not .
    It's designed to cut the fuel off incase of an accident.
    Jan 2010
    Scotland
    Quote Originally Posted by poves View Post
    nope no kerbs involved,
    parked up a good 6 inches from the kerb, switched off, then wouldnt start 30 seconds later
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    The only time this has happened to me (twice!) is the crank sensor in the girlfriends corsa failing, its a petrol though, not sure if it could be the same problem as your having but thought I would mention it!
    Jan 2010
    Scotland
    thats what i'm hoping for something like like a CPS or similar, will get my hands on a solus tonight and get the codes of it, fingers crossed its nothing terminal or the veccy is off the great scrapyard in the sky
    Dec 2011
    Seaham
    How new is the battery in your remote? Could it be the immobiliser?
    Try your spare key and remote.
    Aug 2009
    Wakefield
    similar thing happened to er indoors old car...... if the engine is turning ove rquite fast then it could well be the timing belt...... she was juts pulling up and befor she parked fully the car lost power, so she tried starting it a few times and it wouldnt, which is probably what ended up destroying the vavles....
    hopefully this isnt the case for you, but if its spinning very fast when you try and turn it over then stop what you're doing and check the belt!
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Does it sound like the engine is struggling to get air in? look up the throttle valve fault, the valve can fail and the butterfly valve slams shut in the intake stopping it getting any air. Unplugging it is a quick fix.
    New Member DSS's Avatar
    Apr 2012
    Anglesey
    I would also think it is the crankshaft Sensor, they tend to need cleaning every 2 or3 years.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    mine used to be a pig to start since new cam and crank sensor it starts on the button.
  1. CDTi turns over but wont fire
    By Malcste in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2011, 14:40
  2. HELP! Car wont start, Engine turns over.
    By CDTI120SXI in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2011, 13:57
  3. 1.9 cdti turns over but fails to start
    By swifty776 in forum Engine & Drivetrain
    Last Post: 9th January 2010, 22:57
  4. 1.9 120 cdti turns but won't start
    By weatherforcast in forum Engine & Drivetrain
    Last Post: 3rd March 2009, 14:25
  5. 1.7 CDTi with CR1 on 21 turns
    By AJA in forum Diesel Engine related
    Last Post: 12th April 2006, 08:19
