Thread: Rear brake light bulb warning won't go off
    Worksop
    Default Rear brake light bulb warning won't go off
    After I've fitted a new bulb?
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    37 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by tomo41 View Post
    Any sings of corrosion inside the holder where bulb is touching the base ? I guess that's nearside brake light too ...
    Worksop
    Quote Originally Posted by Sebastian View Post
    I'll ave a look it's pass side rear one it's working but light is still on
    scottish region
    Take a picture of rear of vectra with lights on
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It can be confussing as the safety feature on the Vec is to use the sidelights as brake lights in the event of a failure of the bulbs take a picture and also have a slow hard look at the brake lights
    11 Post(s)
    Quote Originally Posted by paulhb View Post
    To be pedantic, the brake lights use the lower tail lights when an upper tail/brake light bulb fails.
    Worksop
    Is the brake light a single or double one?
    They are all single
    When braking the module increases the current, making the bulb brighter
    Using cheap bulbs can result in low current, the module then returns this as a bulb failure
    When I receive such a warning, I reverse up to a shop window or the likes during darkness, then view the rear of the car to see which bulb is at fault
    I had a relative do this during daylight and they couldn't see which bulb had failed, so I had to get them to press the brake pedal and I quickly identified the brake bulb that had failed
    11 Post(s)
    They are all single
    Increasing the current won't make them brighter. It's a voltage increase.
    All bulbs are 12V
    The current varies, which in turn increases the power output
    Hence why on tail it is 5W (just under 0.5A) and on braking it increases to 21W (just under 2.0A)
  1. Bulb warning light
    By corm in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2011, 19:03
  2. Brake bulb warning light
    By SeeDeeXeye in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2009, 02:42
  3. bulb out warning light
    By redarmy990 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2009, 09:22
  4. rear brake light problem, bulb ok, please help
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2009, 18:29
  5. Brake bulb warning light
    By steve1975l in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 19:11
bulb wont go in break light bulb gos
