Results 1 to 10 of 19
Thread: faulty(loose) headlamp plug help please
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default faulty(loose) headlamp plug help please
    Thought my hids had finally given up tonight as for last couple of days passenger side has worked when it wanted to...........anyways had it stripped down and replaced back to standard bulbs but fault still persists, turns out passenger side headlamp plug is very loose and not making a good connection.
    has any of you had problem and got an easy fix?
    thanks Andy
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Can you bend out the spring/clamp that the bulb blade goes into?
    Jun 2009
    bradford
    hi mate
    sorry mate.I wasn't clear, its the main wiring plug from car to headlamp with all the wires for the headlamp, it seems to locate ok but doesn't make the connection unless i press really hard and then just loses connection when I let go
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Just saw your second post so I have deleted what I was going to say as it have no relavence to your problem
    Sorry
    Vehicle : SRi
    Mileage : 137000
    Yea, you can press these in more for a better connection, or am I still of the mark?
    Jun 2009
    bradford
    lol.........its me guys not you lot
    if you remove headlamp from car, there is a big plug on back that controls all functions on headlamp, probs about 12 wires in it, it has a big pull out locking thingy....this is the one that doesn't seem a tight fit and not making the connection .........so I have nothing working in that lamp, hope that makes sense
    Jun 2009
    bradford
    no rushy ...the main plug which you have to remove to take headlamp out of car mate
    Vehicle : SRi
    Mileage : 137000
    Arr sorry mate, I take it its a facelift thing.
    Jun 2009
    bradford
    no mate.......lol, its part of the loom that plugs into your headlight....not model specific
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    The bit that has the red locking mech on?
  1. Loose plug left side
    By nipmads in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2012, 09:27
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. misterious plug just hanging loose ?
    By melvyn8181 in forum Diesel Engine related
    Last Post: 21st July 2011, 22:19
  4. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  5. Whats This?... Loose plug in boot
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2010, 23:29
