Thread: Signum Rear Spoiler
    Regular Member sol's Avatar
    Farnborough
    Engine : 2.0T
    Mileage : 63000
    Default Signum Rear Spoiler
    Is it possible to remove a rear spoiler thats been bonded with Tigerseal/Sikoflex?
    Apr 2011
    Las Vegas
    mmmmmmmm it is but its hard stuff to get off, try not to snap the spoiler. You could try to put a slim blade under it and move it along nice and slow to free the bond.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    And its likely to make a right mess of the rear door as well.
    Regular Member cdx2.5's Avatar
    Apr 2012
    Preston
    Trim : Elegance
    Engine : 1.9 cdti
    I've used cheese wire before to remove a spoiler its the stuff windscreen fitters use to remove windscreens that are bonded on
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    i removed the spoiler ive now got on mine from a tailgate and believe me it
    takes hours,i used everything inc cheese wire but the problem youve got is
    were the top of the tailgate bends over to the rear glass as thats were the
    wire seems to get stuck and it also cuts into the tailgate
    i managed to loosen the top and some of the botton but round were the
    brakelight area is then i ended up inserting a wood saw to cut the bonding
    around that part of the spoiler,i did end up repairing some areas of the
    spoiler but after hours at it then it gave and came in 1 piece
    oh just another tip,it helps alot if the spoiler is heated up along the edges to soften it
    you can use a hair dryer or fan heater etc
    WGAF#5
    I purchased a roof spoiler off of eBay that had been removed with cheese wire .... Too me a week to sort out the Damage that it had prior to prepping and spraying
    It can be done ... But cleaning off the old sickaflex takes an age ... And the potential to get it al wrong is very high
    Farnborough
    Engine : 2.0T
    Mileage : 63000
    Thanks for all your comments.
    It's helped me make my mind up that I should steer clear of a second hand one thats already fitted to another car.
    Guess I'll have to keep my eye out on ebay for one at a reasonable price and not the extortionate amount Irmscher charge!!!
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    the repro one caveman nige has got is good ..
    a copy one of the bayofE
    Regular Member dahmich's Avatar
    cwmbran
    after looking at kmans and a few others on here, ive decided i want one, when i sort out the issues my car has....
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Theres one on fleabay at the moment http://www.ebay.co.uk/itm/1306901839...84.m1423.l2649 doesn`t look to bad i bought mine of ebay and looks ok now fitted i used a heat gun to remove the old sikaflex HTH
  1. Signum Rear spoiler
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 21:31
  2. signum rear spoiler
    By jsnlvxr in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 16:44
  3. Signum Rear Spoiler?
    By signumart1 in forum Bodywork & Interior
    Last Post: 13th January 2008, 18:31
